Results 1 to 9 of 9
    Veteran Member Four Rings 1.8Titorey's Avatar
    Mar 04 2004
    97 A4
    Fremont ca
    Question how do you remove this?
    I'm planning on wiring an amp in my trunk and was wondering how do you remove the plastic pieces that run all the door sills? Is it just held on by clips? TIA
    Veteran Member Four Rings 4ingDrive's Avatar
    Feb 25 2004
    Chi town burbs
    It's just clips.
    99.5 A4 Avant
    always some shit broken
    GTA, Canada
    You can actually push the wires up under it though, don't have to remove it if you don't want.
    RippleChip (Ryan) - Moderator
    Audizine
    01.5 eh4 1.8T || 12 eh5 2.0T
    Mar 04 2004
    97 A4
    Fremont ca
    im not sure if the power cable will fit under there but ill give it a try.
    Feb 12 2004
    99.5 1.8T A4
    Cleveland OH
    just pull it, it will come right off.
    Feb 25 2004
    Chi town burbs
    It's real easy to pull off.
    99.5 A4 Avant
    Registered Member Four Rings Zodiak's Avatar
    Washington DC
    what people haven't said yet, is that you need to remove the kick panel (piece withthe dead pedal) first. The screw for it is right next to the hood latch. Remove the screw and the panel slides out, then pop up the interior siding
    GTA, Canada
    You can stuff a power cable under, though it will be a lot easier to remove.
    Audizine
    Veteran Member Three Rings Kurzer's Avatar
    Feb 12 2004
    MkV VW Rabbit
    Beaverton, Oregon
    Thank you: MatrixIntegrated
