Results 1 to 15 of 15
    Feb 12 2004
    2002 A4 1.8T Tip/Q/Xenon
    Sacramento
    Want bluer color for your headlight for free without losing lumens?? Read this mod
    I have done a small mod on the projector as part of the research. Here are 2 cutoff beam pictures on a wall that I took before and after projector mod:
    Before:
    After:
    Any comments????
    The projector that I use is a Halogen Ecode projector with my HID kit. You will get the similar result using your existing DOT projector(of course the cutoff edge will look different but color wise it is the same). This mod can be applied to both halogen and xenon housing.
    There is no change of bulb whatsoever, it is standard OEM xenon bulb. So it still have maximum brightness without losing lumens.
    Now... How did I do that? Pictures will follow soon....
    Veteran Member Four Rings A4 in SC's Avatar
    Feb 16 2004
    '84 911 Carrera GP White, Burgundy cloth
    Simpsonville, SC
    I can't wait to see what you did. Honestly, mine look alot like the second pic, although I do have E-Code HIDs...
    Mike
    Feb 15 2004
    2009 M.B. C300 Sport 6Sp
    T.O. Canada
    tell me more !
    Feb 17 2004
    Sterling, VA
    I'll wager that the distance between the bulb and the cut-off shield is farther on the second one.
    Brett - Moderator
    Issue?: email me.
    _____________________
    Stage 3 2004 A6 2.7T 6M
    Veteran Member Four Rings nmb's Avatar
    Audi A6 Avant 1.9TDI Sport '01
    Lat: 38º45.06'N Lon: 009º16.32'W Portugal!!!
    looks great! show us how please!
    MY2002 Audi A6 Avant 1.9TDI Sport OEM Plus
    Alu Roof Rails, Alu Mirrors, S6 Door Blades, 19" Gallardo Reps, S-Line Sport Seats, S-Line gear knob, NavPlus+DVD.
    Account Terminated Four Rings MR VTEC's Avatar
    98.5 Audi 1.8TQM
    Brooklyn
    we are going to boycott yo A$$ if you keep us in suspense any longer you hear me
    Registered Member Two Rings
    May 16 2004
    98 A4 2.8qm
    Registered Member Three Rings excursion's Avatar
    Feb 20 2004
    Audi
    Lincolnshire, GB
    Nice work chief
    West LA, CA
    The second pic loses the sharpness in the cut off, the light is scattering on the left. This is a problem when the light hits the road at a great distance. It looks like you changed the distance between the bulb and the projector causing it to not focus properly. I might be wrong but thats my guess. Spill the beans already.
    Feb 12 2004
    Sacramento
    Actually the lens and the bulb are at the same position. I pushed the cutoff shield inward towards the bulbs for about 1mm.
    So the bulb is still focus and you wont have that problem. As you can see, the sharpness is still very good.
    But the slight bend in the shield has amplified the prizm effect of the cutoff and therefore the blue light stand out more.
    I have checked that it is not creating any lighting performance problem even at great distance.
    Feb 12 2004
    99.5 1.8T A4
    Cleveland OH
    so you just pulled on it with your hand?
    Feb 12 2004
    Sacramento
    You can use your hand if you wish, all you need is just 1mm and you will have a very nice color. :)
    You may have to take out the projector from the headlight before doing that, or if you have tools that let you pull slightly, it will work as well.
    Feb 17 2004
    Sterling, VA
    This is pretty funny stuff. I was talking to Evil on AIM a few months ago about this very same mod. I originally read about it here:
    http://faq.auto.light.tripod.com/projector-unit.htm
    (See the section called: "What creates the colorful cutoff band?")
    I took my projectors out of my housings and tried to bend the cutoff shield towards the bulb and it really didn't make a great difference. It did how ever, cause my cutoff to become sloped at the edges because the cutoff was now angled towards the light source.
    Brett - Moderator
    Issue?: email me.
    Feb 12 2004
    Sacramento
    You cant bend it too much. As you can see.. it created the blue just-about-right.
