Results 1 to 9 of 9
    Veteran Member Four Rings bong2611's Avatar
    2000 A6 AVANT, 2004 MBZ ML350
    Newark, Ca.
    HID fuse question
    I seem to be blowing my 10amp fuse for my headlights eversince i swiched over to HID's. If i flip the switch on a couple times fairly quickly is when the fuse seems to blow. I remember reading that some replaced the 10amp with 15amp fuses. Would this be ok. TIA.
    Established Member Two Rings wakko's Avatar
    Apr 08 2004
    Temple City, CA
    I read from the install guide that IF it blows your fuse constantly with the 10amp, you should change to 15.
    2000 A4 1.8T FWD TIP / 20%F 15%R tints/GIAC 1.0/ GIAC TIP / Full 2.5" DP back custom exhaust / Flik WASP-A 18" / RS4 grill / Ecodes / OEM RS6 4300k HID / Reiger V1 sides / Painted Front lower / Molded SGI rear / Apex Cupkit Suspension / Greddy TT / AutoMeter Boost Gauge / Audi all-weather mats / Forge 007 DV
    Veteran Member Four Rings Devious27t's Avatar
    Mar 02 2004
    2001.5 S4 Avant on Corn
    Orange County
    that would seem to me like you are just covering up your problem... think about it, you are installing a 35w bulb essentially and taking out a 55w (using less power) why would you be blowing fuses? i dont have a problem with it, i would advise just checking over everything and making sure that it is correctly wired maybe search around for protocolD's install instruction and make sure yours is like the way he advises, i followed it and have no problems whatsoever.
    Feb 12 2004
    2002 A4 1.8T Tip/Q/Xenon
    Sacramento
    Actually he should be looking at 15. The power consumption of HID (35W) is less than halogen (55W) when it has been lite up.
    However, the power it will draw when it first ignite is much much more than that and that's why he blow his fuse when he try to turn it on and off too quickly.
    Registered Member Three Rings A4-Vblack's Avatar
    Feb 19 2004
    A4 2.8MQ
    Austin, TX
    What Proto said. When you turn on the HIDs you can feel the electrical system take a hit and then catch up. My 10 still works for me, but I might switch out to the 15 just to be safe.
    http://www.audizine.com/gallery/data/500/709S4_Sig.jpg
    2000 S4 / 18" RS4 Wheels / RS4 Grill / HW Val 1
    Mar 02 2004
    Orange County
    ah learn something new everyday.... eh either way my 10 amp works fine....
    May 20 2004
    More cars
    Never Land Ranch
    my 10 amp works fine too. I might just keep a 15 in my car just in case
    SEXICAN
    2013 Q5 3.0T-DD
    2002 Honda Civic
    AMD/EPL Tial 605 B5 S4 SOLD
    Feb 12 2004
    Sacramento
    HIDs startup power are around 150W.
    According to Physics. Voltage x Current = Power
    12V x 10A = 120W max.
    12V x 15A = 180W max.
    That's pure calculations. Actual power consumptions varies.
    As you can see, it is save to use 15A fuse and that's what being used in all aftermarket HID system.
    Newark, Ca.
    thanks a lot guys. Got the 15amp fuses installed...
