Page 1 of 3 123 LastLast
Results 1 to 40 of 104
    Veteran Member Four Rings enigma1406's Avatar
    Sep 17 2006
    2013 S8 | 2006 S4 Widebody | 2014 Q7
    Houston, TX
    S6 LED DRLs on a B7
    Posting here as well because I know at least 2 B7 A4'ers that wanted to do this.
    I finally decided to go through with this install. I bought the LEDs a while ago and was planning to do the install myself. I quickly found out that this was not going to be an easy install. The LED array is wider than the fog area and attaching it to the bumper would not be an easy task. As a result I enlisted the help of a local body/performance shop that has a really good reputation on the local forums.
    Am I a poser for putting an S6 piece on an S4? Sure. Call me whatever you like. I have RS4 pedals and RS4 replica wheels as well, so I guess it's a bit of a theme with my car.
    The install is not done, so I only have some in progress shots. I'm not sure exactly when it'll be done, but if it's not done by this Friday then it won't be for another week or two. I lost the fog lights (my choice) because there just wasn't enough room for fogs and the LEDs both in terms of physical fitment and visual appeal. We decided to mod the stock fog grille to fit in with the LED array to keep a slightly more OEM look so it doesn't look like it's just stuck on.
    Here are the in progress shots:
    The only visual parts that are cut are the fog light holders. You can see that the outside is recessed behind the bumper but the inside sits flush with no need to cut a notch.
    Both sides on.
    The grille in progress
    Not having my car to drive sucks! But I think it'll be worth it.
    Established Member Two Rings dinorawrrr's Avatar
    Mar 20 2007
    '02 A4 Blue Demon, ///AMG
    Re: S6 LED DRLs on a B7
    I've been thinking about doing this on my B6, but when I think about the amount of work it would take to make it look OEM, I quickly lose interest. By the looks from your pictures, it looks like a lot of work as I expected, but I must say you are going about it the right way. The last couple pictures I can see it come together nicely, and it was a good idea to lose the fogs. Makes me want to give it a try still, but not sure if it is worth the time and money. But in anycase, it looks great so far, and it will look even better once you get those fired up!
    Sep 17 2006
    Houston, TX
    Quote Originally Posted by dinorawrrr View Post
    Here are some pics of other installs. Really not a fan of the B7 install and for some reason the B6 install looks a bit out of place with it at the bottom to me, but I'm picky.
    B6:
    B7 Cabrio:
    edit: these are stolen from here: http://www.passatplus.de/umbauteile/...-tfl/index.htm
    If you want to make it work like the S6 as well (dimmer at night/with headlights and brighter during the day/no headlights) then you can use that circuit. Just limits the power going to the LEDs with pulse width modulation. Easy stuff for a EE.
    Veteran Member Four Rings Sanjman's Avatar
    Nov 16 2006
    nothing else special
    Skokie, IL
    Quote Originally Posted by enigma1406 View Post
    B6:
    B7 Cabrio:
    I'm jizzing in my pants... how much is it costing you?
    Senior Member Two Rings teknikk7's Avatar
    Jul 26 2007
    Chino Hills
    Where can I order these lights?
    Thanks, Robert
    Jul 26 2007
    Chino Hills
    Thanks, Robert
    Jul 26 2007
    Chino Hills
    Thanks, Robert
    Veteran Member Four Rings TSlice's Avatar
    May 18 2007
    Houston
    What shop is doing the install? It's good to see someone finally following through on this idea, I think it will look awesome when it's done.
    Sep 17 2006
    Houston, TX
    Quote Originally Posted by TSlice View Post
    Forgot to mention that. HAP (Huntington Automotive Performance and they also go by Huntington Automotive Repair and Body Shop). They do regular body work and stuff as well as performance mods. Peter is the man to talk to. He's got skills and so do the other guys at the shop.
    Registered Member Four Rings
    Jun 14 2007
    2007 A4 2.0T QM 2008 A8L
    New York
    This is one of those mods that's good if you got serious cash to burn. I can't say it doesn't look nice so far, please post more pics!
    Sep 17 2006
    Houston, TX
    Quote Originally Posted by Tiesto View Post
    I wouldn't say I have cash to burn. I'm a frugal guy other than when it comes to my hobbies, which includes the car. I'm not just aimlessly spending money. I have it all budgeted out. I'm a dork, I know.
    Jun 14 2007
    New York
    As long as it doesn't look anything like that other B7 you posted it should be a pretty decent mod. Good luck!
    Sep 17 2006
    Houston, TX
    Has anyone tried to put these on a B6 S6 yet?
    Thanks! That's the plan...I showed those pictures to Peter at HAP and he said something along the lines of "If I do that to your car you can shoot me." Good man.
    Oct 22 2005
    Reppin the Mitten.
    i wonder how that would look on a b6 usp. I think the s6 leds are too big for that grill area tho. Mind to tell me how long it is?
    Sep 17 2006
    Houston, TX
    Damn, I forgot how long they are. MadAudi (where I got them from) lists the dimensions at 20"Length X 3"Width X 5.5" Depth. I want to say those dimensions are a bit off because the whole thing curves, but that is probably a good guess. If you have access to a B7, the curvature and length is almost exactly the lower part of the fog area. I didn't want them to be down there so we had to tuck the outside a bit.
    Mar 20 2007
    Yeah, it doesn't look good on that B6. First off it looks like they were slapped on, and 2nd they need to be above the fog lights. I think it looks good on the grey B7 in terms of overall flow and fitment, however still somewhat of a hack job. Yours should look great though since you are spending the time and money to mold them in and the location should be ideal.
    I believe they can be made to look good on the B6, but I think it would require the right bumper, and some custom fabrication/molding to look right since the S6 LEDs are not the ideal fitment for the B6.
    They do looks sweet though...sigh....
    Veteran Member Four Rings bunnn's Avatar
    Jan 24 2006
    e92
    mine should be done in 2 weeks at most... how do you plan to wire them?
    Cheers!
    ~Ben
    Deactivated Three Rings Coker Rat's Avatar
    06 2.0T A4 w/quattro
    Fort McMurray, Alberta
    Bad Ass! on the B7
    May 18 2007
    Houston
    Looks awesome on the B7 cabrio. IMO they definitely need to be mounted on the top of the fog light opening to look right. Your install is 999999x cleaner than the cabrio -- should look OEM . Keep us updated.
    Dec 27 2005
    New Orleans
    cant wait to see the finish product, i think you made a wise decision not going with the fogs and leds
    Veteran Member Four Rings rds0000's Avatar
    Oct 03 2006
    E90 M3- 997tt-Jeep
    Should look nice, and original......dork.
    Senior Member Three Rings RealSanaii's Avatar
    Jan 23 2006
    2005.5 Audi A4
    Great Falls, VA
    May I ask how much total?
    DARK SIDE....
    Account Terminated Four Rings
    Apr 12 2007
    2010 Ford Edge AWD
    Mr. 630
    Damn, the cabrio butchered his/her fog openings.
    Veteran Member Three Rings greg@dubaudi's Avatar
    Feb 05 2005
    2001.5 pearl WB Avant, 2016 SQ5
    Alton Bay, NH
    Nice work man Im finishing up my install today I will have pics after waterfest.. I used a diff grill set up I used the OEM fog grill cut out and molded in a TT center grill mesh, looks just like RS4 mesh and goes with my grill....
    2001.5 EPL/Tial 770 Pearl WB Avant///2021 SQ7 Nimbus Grey///2021 GMC 3500 Duramax
    Veteran Member Four Rings quattshot's Avatar
    Oct 27 2006
    East Ft. Lauderdale, Florida
    Wow, it looks good on the B7 from FAR AWAY.
    It looks horrible on the B6.
    None of those pics are great examples of a CLEAN job.
    I hope yours comes out clean as a whistle.
    Currently in the market for an Avant or Allroad.
    2007 A4 2.0 Quattro Silver/Blk "Quattshot Edition" Too many upgrades to list.
    2000 S4 Race Spec Champion Motorsport Edition. Too many upgrades to list.
    Senior Member Two Rings jackk's Avatar
    Oct 10 2006
    B7 A4 Avant
    MTL
    finally someone's doing it right, can't wait to see the final result. and i second the costs question.
    Jan 18 2007
    sarasota.naples
    Someone should really get on a B7 LED kit. sign me up!
    Sep 17 2006
    Houston, TX
    I'll post a figure once it's done. No saying what it'll be now. We talked ballpark numbers and he said he wouldn't charge for R&D since this is his first time and he can leverage this when other people want similar installs.
    The basic wiring will be an independent switch that is ignition controlled. I haven't stopped by to see exactly how he's wired it up, but I'm heading there tomorrow and I'll ask him then.
    I was thinking about doing RS4 mesh with the grille but the honeycombing from the RS4 fog grille I have was a little too big for it to look decent. That might be something that is added later on if I really feel like it's lacking, but honestly I think it'll look good as it is.
    Quote Originally Posted by DVS-B7 View Post
    That was the first thing he asked me when I brought the car in. He goes "are you sure nobody's made a kit for this?" to which I say "yea I'm pretty sure" and then he goes "ok, cool, well i like a challenge so here are my thoughts..." He's got mad skills.
    Sep 17 2006
    Houston, TX
    Oh and thanks for the kind words and encouragement!
    Jan 24 2006
    e92
    have you ever considered the way of filling up the wholes like how our 3.2s naturally are covered..that piece of plastic.... i figured the rs4 mesh might look weird if its not on right and just imagining it already feels weird...thats how i plan to fill the gap..anyways looking forward to your results/final product=)
    Cheers!
    ~Ben
    Veteran Member Four Rings redhott06's Avatar
    Mar 15 2007
    2006 A4 2.0t
    Bedford, NY
    looks awesome.. this will probably be my next big mod! the led's were backordered from madaudi i believe. but i love the way its coming so far!
    06 Brilliant Red A4 2.0T stage2+
    sparco, bbs, revo, stasis
    [email protected]
    Jul 20 2007
    '89 Toyota Pickup, '00 Miata
    NJ - 908
    Fogs delete is definitely the way to go IMO. Your install looks clean which is way more than half the battle. This mod is not to my personal taste however.
    2007 BB A4 2.0TQ Tip, 35% Tint
    Senior Member Three Rings eLusive's Avatar
    Dec 19 2006
    Jack Purcells
    Laguna Niguel, Ca
    WOW clean installation man !! that is quality sir..
    2010 EVO X GSR 460awhp/389awtq
    **SOLD**2007 Audi A4 2.0t Brilliant Black Quattro 6MT S-Line Ti Package [fully loaded w/o Bose & Navi]
    Mods|APR 91|ECode TP|Britalman Quad Tip Dual Exhaust|K&N Drop-In|19" BBS LM Reps|S4 Rear Valance|13% Tint All Around|CC Mod|Defi Meter BF [amber] Boost Gauge|CF DTM Wing|Seat Leon Cupra R Splitter
    Veteran Member Four Rings INTEGRATION's Avatar
    2006 A4 2.0T Quattro 6MT
    AWD_4TW
    I think your version of the install is the cleanest. It looks kinda weird to keep the fog lights.
    2006 Audi A4 2.0T Quattro 6MT S-line
    Senior Member Three Rings booch's Avatar
    Sep 16 2006
    2014 S6
    Nashville, TN
    Quote Originally Posted by INTEGRATION View Post
    ^2nd...anxious to see how yours works out
    Veteran Member Three Rings Echo3One's Avatar
    Apr 02 2007
    Phoenix
    I think it would look good if you delted the fog lights and put mesh there.
    2021 Audi RS7 | Nardo Gray | Cognac Interior | Carbon Optic Package |
    |Eventuri Carbon Intake System |Akrapovic Evolution Titanium Exhaust | CETE Active Air Suspension Lowering Module |
    2010 Audi S5, 6-SMT | Meteor Gray | Magma Red Interior | Prestige Package |
    | APR Supercharger | STaSiS Exhaust | STaSiS Touring Suspension | STaSiS Cast Wheels 20 x 10 |
    Oct 10 2006
    B7 A4 Avant
    MTL
    I don't see the point of mesh, it will just block airflow to the turbo
    Sep 17 2006
    Houston, TX
    Quote Originally Posted by jackk View Post
    I don't have to worry about that. There is a radiator over there though, but the mesh wouldn't block enough airflow to make any difference. If anything, the LEDs themselves block the most air.
    Sep 17 2006
    Houston, TX
    I picked up the car on Friday but the grilles weren't completely done, so it looks a bit ghetto atm. The lights work and everything though. I'm going to get the grilles put on Tuesday or Wednesday, so I'll take pics then and post them up.
    Dec 18 2004
    houston, texas
    let me know when you head up there, id love to see it in person.
    mattchow -- 2015 vw golf sportwagen + 2010 vw apr k04 gti (for sale!)
