Results 1 to 11 of 11
    Apr 25 2004
    Kansas
    HELP! Finishing TB change, and i cant get the d@mn lower radiator hose on. It seems
    lined up and im pushing with all my stregnth, but it just wont budge. What am i doing wrong?
    Veteran Member Three Rings JpnA4Quattro's Avatar
    Feb 19 2004
    2001 Audi A4 Quattro 5spd,
    Santa Barbara
    push harder, it will eventually get on there, if not use some veg. oil(do not get it into the hose) which will allow it to slip on there easier, once its in and locked, its hard to get off.
    Feb 17 2004
    Sterling, VA
    The radiator hoses have these metal locking clips on them to keep the hose locked onto the radiator inlet/outlet. You have to lift up on the clip while removing or connecting the hose.
    Brett - Moderator
    Issue?: email me.
    _____________________
    Stage 3 2004 A6 2.7T 6M
    Veteran Member Four Rings marked001's Avatar
    Feb 17 2004
    08 Subaru Impreza WRX; vr
    South Philadelphia
    that hose is def. a b!tch I cant remember if I had a harder time taking it off or putting it on itll go though..just take a break and try again.
    F the Jersey Jerks
    Jersey Jerk hata #1
    99.5 t28 A4 ....bye bye.
    www.REVI21ON.com
    Feb 19 2004
    Santa Barbara
    taking it off was a lot harder for me than putting it back on. The veg oil helps out a lot.
    Registered Member Two Rings SilverA4Fun's Avatar
    Feb 18 2004
    2000 A4 1.8TQM
    Arlington, VA
    make certain the clip is up/out and just wiggle it on. It sjust tought since there is minimal room for your hand/leverage
    Friends don't let friends drive stock.
    Senior Member Three Rings Benfica09's Avatar
    yup, that part is such a PITA, especially since your almost done, and you just want it all back together.
    like the others said, make sure the metal clip is up, and just keep wiggling/pushing it.
    its a pain, but it will slide into place.
    Jersey Jerk #9
    gone: 98 A4 supercharged / 99 Viggen / 01 225TT coupe / 07 Cooper S
    Apr 25 2004
    Kansas
    F*ck yes, im done. I heated the hose up for about 5min with a hair drier and pushed really hard, and it went on. Piece of shit hose....but i feel great. Up to this point, all i'd done was oil and spark plugs on a jeep. Did the whole timing belt with minimal help. God it feels good.....
    Feb 17 2004
    South Philadelphia
    def. a great feeling of accomplishment..congrats
    F the Jersey Jerks
    Jersey Jerk hata #1
    www.REVI21ON.com
    Dec 21 2006
    97 1.8TQM
    Sacramento
    Re: HELP! Finishing TB change, and i cant get the d@mn lower radiator hose on. It see
    I replaced my tb last weekend and the lower rad hose popped off last night and I lost all my coolant. I used the hair dryer and veg oil and got it back on. Thanks!!
    ps. I just had to bump it :o
    Veteran Member Four Rings Rosati's Avatar
    Nov 17 2004
    B5 Brilliant Black A4 1.8TQM
    Northern New Jersey
    Get under the car perpendicular.
    hold the bumper with one arm and push in, going up and down at the same time while pushing (with the metal clip up) then when u pushed it in and wiggled it on there tight, push that clip down and check to see if it comes off.
    It takes quite some strength
    (for future reference)
    Congrats.
    * Gone but not forgotten - BTA4 GT28RS w/ all mods 400chp
    https://www.facebook.com/media/set/?...1463643&type=3
    Current: 1994 Mazda RX7 Chaste White
    DIY B5 Head Replacement Guide: http://www.audizine.com/forum/showth...al-and-Install
