    Registered Member Two Rings jmh's Avatar
    Jun 27 2004
    Audi A4 1.8T
    Sweden
    How´s the fit of kerscher??
    How dose kerscher fit, Front and side??
    I now there are made of fiberglas so maybe the fit is bad. But please tell how it is..
    And if it is hard to install..
    Feb 13 2004
    A4 3.0 QM
    Weston, Florida
    The fit and quality is excellent. You just have to be methodical in how you work. Definitely remove the entire front bumper for the front valance install. The instructions say do it on the car. After installing mine on the car, Don't. You will get a better fit and it will take you less time in the long run if you remove the entire bumper. I found the adhesive they give you kicks off quickly in hot weather giving you no time to position the parts correctly. Get a panel adhesive from a Body shop that takes awhile to kick off. When you install the screws and backing clips connecting the lower part to the upper, trim the excess off the screws otherwise they will catch on the underneath of the metal front crash/support bar when you re-install the entire front. The sides are easy. Remove the factory rubber/plastic strip.Save it. Install the Kerscher sides with the original Torx screws. Re-install the rubber/plastic strip over the screws with 3M VHB tape. Retains the factory look. Just take your time. It is well worth it.
    Jun 27 2004
    Audi A4 1.8T
    Sweden
    a4s:
    Thanks... Very good.
    If you have some pics of your car please send me an email with them.
    Feb 10 2004
    2019 Mk7.5 Golf R His/Her
    Eastvale
    click my sig and look in the photo album that has audi audi audi there are some pics of my buddy's car
    Instagram: @daohaus_garage
    Feb 13 2004
    A4 3.0 QM
    Weston, Florida
    Check out my album in the Members Gallery section. Type in A4S.
