Results 1 to 11 of 11
    Feb 23 2004
    Audi A4 1.8T
    Los Angeles CA
    impressions of my elemental designs e8a.44
    well...finally after ALOT of time and frustration, i got one sub up and running...and all i have to say is....
    OH MY GOODNESS SOOOOOOOOOO FREAKIN CLEAN.
    this has to be one of the cleanest subs i have EVER heard. this one tiny 8" sub extends so low...about the same as my 2 15" crystals did...the low end extention is simply AMAZING. the middle and upper bass is perfect....precise and tight. the clarity is unbelievable. the volume is a little less than what i would want in a sub...but i need alot. after having 2 15"s and my w7 ported...i need a decent amount of power. if you're looking for an extra oomph, this is MORE than enough. if you like listening loud then this is PERFECT. i just need a little bit more.
    im almost absolutely positive that when i toss in my 2nd 8 the volume will be more than enough.
    here are some more details for those who care.
    the sub is an elemental designs e8a.44.
    450watts rms
    dual voice coil 4 ohms each
    box is .28 cubes sealed, about .23 cubes after displacement of sub and wiring...gives me a qt of slightly under .707 iirc...
    amp is avionixx 800.2
    running stereo, one channel to each coil at 4 ohms
    200 watts x 2
    400 watts total running sub
    all i have to say is WOW. this 8" sub has impressed the **** outta me...i might just ditch the 15 altogether and toss 4 8s or something in the trunk...
    its THAT CLEAN
    Feb 23 2004
    Audi A4 1.8T
    Los Angeles CA
    oh yes...props to Jeff on AZ for helpin me through some box calculations. im sure the almost perfect box dimensions contributes to the awesome low end and tight high end on the sub...
    Feb 23 2004
    Audi A4 1.8T
    Los Angeles CA
    i cant wait to install my comps for that extra kick in midbass...then my system will be very balanced...
    then i get to drop in that nasty 15" to disrupt that balance a little...
    just a little ;)
    Feb 13 2004
    Socal
    i like how you replyed to yourself TWICE! haha congrats on the setup.
    Feb 23 2004
    Audi A4 1.8T
    Los Angeles CA
    yeah...just some things i forgot to add in the first post...
    Veteran Member Four Rings hyperspeed's Avatar
    Feb 13 2004
    Chino Hills, CA
    good stuff!!
    Veteran Member Four Rings fongaroos's Avatar
    Feb 12 2004
    cali
    IM COMIN OVER NOW!!!
    I WANNA HEAR!!!
    Registered Member Three Rings BrokenXenon's Avatar
    Apr 28 2004
    how much is that thing approx?
    Feb 23 2004
    Audi A4 1.8T
    Los Angeles CA
    eric gimme a call later if u wanna meet up and check it out. i got work til 6.
    the sub sells for 185 iirc but its discontinued. you will never find one new again. your best bet is to find one used, or go with a different line. elemental designs is coming out with with the v2 version of this sub somewhere down the line...which could mean a a month to...really really far away.
    i would look into their other subs as they are all excellent...
    Veteran Member Four Rings audidood's Avatar
    56 Oval, 2017 Tacoma
    san diego, ca
    TPIWWP!
    2004.5 USP A4 1.8t with mild mods.
    1956 VW Bug with major mods.
    Feb 23 2004
    Audi A4 1.8T
    Los Angeles CA
    pics are useless. the box looks like a piece of crap. i got too eager to do it right, plus im going to buy new wood and make a new box...
    i just tossed it together, sealed it up and played...theres glue everywhere and it just looks like crap.
    however it does sound excellent =)
