Results 1 to 3 of 3
    Veteran Member Four Rings shehatezme's Avatar
    12 BMW F10 528i | 02 Honda S2k
    Bay Area
    One HOT 1982 Volvo 242ti
    I love people with projects like these. 1982 240 Flathood. Stock motor comes with turbo.... this guy took a POS and made it into an amazing car. Got this from another forum.
    Check out POS pics here:
    http://www.clubvolvo.com/forums/show...s=&threadid=54
    BEFORE
    AFTER
    ya thats the first production CF volvo 240flathood in the world (that I know of)
    4 pot brembos 330X32mm brembo discs courtesy new S60Rs
    lots and lots of pictures at http://www.pbase.com/dkauer744
    Its the project car for http://www.clubvolvo.com
    pretty much everything but some welding and the paint I did/built/figured out/fabbed my self
    Drivetrain:
    Rebuilt B23FT (2.3L), decked, oringed. Mircopolished crank, hi flow oil pump.
    398 head pocket ported, polished, match ported, shaved, 3 angle valve job
    Enem K15 cam 298* duration, 13.2mm lift
    IPD adjustable cam gear
    Holset HY35W turbo, -8AN braided feed, -12AN braided return line
    Proturbo.fi full tube, equal length header
    Tial 38mm wastegate (not pictured)
    NPR Intercooler
    Megasquirt EMS w/ 56lb/hr Lucas injectors, modified to control spark
    B230 intake, Throttle body, Fuel Rail, 3.5Bar fuel pressure regulator
    TurboXS TypeH BOV
    HKS Turbo Timer
    Blitz EBC-S boost controller
    MSD 7al-2
    MSD 8.5mm plug wires, NGK plugs
    Relocated OEM oil cooler
    Innovate Wideband
    4” down pipe
    3” Catco cat
    3” Dynamax Bullet muffler, side exit exhaust
    91 5.0 T5 mustang gear box, adapter from www.v-performance.com
    ClutchNet custom clutch (copper 6puck sprung hub, 100 over PP)
    9lb aluminum flywheel (custom built by www.v-performance.com)
    Pro5.0 Short Shift kit
    Bullit edition shift knob
    1 piece driveshaft
    Dana 30 (1031) axle
    Converted to 3.91 gearing
    Powertrax Locker
    Suspension:
    IPD Sport Springs, 25mm sway bars (front and rear), strut braces
    MVPvolvo.com poly bushings
    Adjustable panhard rod
    Bilstiens struts and shocks
    Cross drilled Brembos, PBR Metal Master pads
    SS braided brake lines
    Volvo Pegasus 17X8 wheels
    25mm spacers
    235/45/17 Wanli tires
    Interior:
    Converted to black interior
    Hand built custom Carbon Fiber dash cluster
    Autometer Carbon Fiber: Tach, Speedo, Fuel, Volt, Water Temp, Oil Temp, Oil Pressure, Boost
    Autometer Pro Comp: AF gauge
    Autometer Ultra lite: EGT
    Corbeau CR1's, 4pt belts
    Innovatemotorsports Wideband o2 sensor
    Sparco Wheel and pedals
    Silver GT themed trim
    Audio:
    Pioneer 6300 receiver
    Kenwood 4" 2 ways in the front doors
    Kenwood 6X9 3 ways in the rear deck
    10" Polk Audio Momo Subs (X2)
    600W Apline Amp
    Custom trunk enclosure built by myself
    Exterior:
    Converted to Group A (racing class) flathood front end
    euro front signals
    87 Trans Am wing
    Waist line trim removed
    Painted Sunset Mettalic Orange
    TurboPerformanceClub.com decal (rear window)
    TPC.com plate holder and euro plate (front)
    Misc:
    Painless wiring fuse block, rewired car from scratch.
    thats about it Im on dougvolvodude if anyone wants to hit me up on aim
    "To be honest Im not sure. Right now it should be putting close to probably 280-300whp down... Im switching over to spark control through my EMS and tuning for 25psi.
    Basicly... I wont rest untill it cuts a 12.0 @ 115 or one or the other lol.
    Last time out I was at 14psi and fighting the car for traction all the way down the track. I only got to make a couple passes and was dropping my ET's ALOT every pass. I think it would have run a 13.0 at the same psi with good traction (damn 2.5 60' times lol). I used to race firebirds before building volvos and they were ALOT easier to get down the track than my 242 (combination of massive boost, not enough tire and a 9lb flywheel lol)."
    Veteran Member Four Rings maxh2o's Avatar
    Apr 13 2004
    B5S4,C2avant,Cgt,UrQ
    San Francisco
    Hmmm, I do have an old BMW 320i sitting in my mom's driveway just waiting to get pimped . . Ben, you interested?
    http://www.audizine.com/gallery/data...70780_copy.jpg
    Dominating the fast lane since 1984.
    Veteran Member Four Rings A4_Andre's Avatar
    Feb 13 2004
    99.5 Audi A4 2.8Q Tip
    Staten Island, NY
    i have a 1980 320i wasting away in my garage!
