Results 1 to 40 of 50
Thread: Gas Mileage...
    Veteran Member Three Rings JHousyS4's Avatar
    May 09 2004
    2001 Black Audi S4 6 Speed
    Gas Mileage...
    I feel I am at the gas station way too much. What's everyone average MPG on their s4 2.7t. Those turbos sure are hungry for some 91 oct. i get 14.5-15.5 usually. SO SH1TTY...what can i do?
    Veteran Member Four Rings duffS4's Avatar
    2009 Audi A4 Avant, 2011 Audi Q7 TDI
    Ithaca, NY
    Wow, that's pretty low. I get around 18/19 in the city and 23/26, depending how heavy my foot gets, on the highway.
    2000 S4
    19.88 mpg on my last fill up.
    May 09 2004
    I dont have a heavy foot, but when the opportunity is open i take it...im cruising, but i shouldnt be getting that low of a average MPG. i NEVER use the air either.
    Registered Member Two Rings
    Feb 24 2004
    00 S4, 00 Jeep Grand Cherokee
    Victoria, MN
    WOW, that is really low.... I average 20.8MPG....
    2000 Tip Silver S4, MTM chip, M3 Lip-Spoiler
    May 09 2004
    Then WTF...what do i do?
    Diamond Bar, CA
    That's a bit low. Maybe add some fuel injector cleaner in there and see what happens.
    May 09 2004
    if i buy some fuel injector cleaner, do i have to put it in on a full tank of gas?
    Feb 24 2004
    Victoria, MN
    Normally you do, yes... just read the bottle.
    May 09 2004
    So i get gas...fill it up, as the bottle reads, thanks ^...without u id be lost. Anyways, i reset the MPG after getting gas. I drive like a girl all the way home to get the average of 16.4! YEA But if i was driving like normal- i wouldnt be surprised to be back in the 13's. Any other ideas?
    Active Member Four Rings Ben@SpeedBarn's Avatar
    03 A6 2.7t, 00 GTI, 76 GMC
    Pittsburgh, PA
    well you gotta give the cleaner till the next tank to see the difference.
    Veteran Member Four Rings aussie_s4's Avatar
    2001.5 S4
    How's the tire pressure? Mine are usually 38psi all round.
    2001.5 S4 - Denver, CO
    - Valeo E-Codes - 710N DV's - Neuspeed 19mm rear sway - StopTech 332mm Front BBK
    - 19x8.5" B7 RS4's - Falken Azenis ST115 235/35/19 - Nokian Hakka RSI 225/45/17
    - RS4 Grille - AutoVation race pedals - XM Satellite Radio - GPS
    Go hard, brake late.
    May 09 2004
    Does that really make a difference?
    May 09 2004
    Does that really make a difference? I bought the car..certified...from KEYES AUDI, about 2 months ago.
    Registered Member Four Rings dramaticstatic's Avatar
    May 13 2004
    2000 S4
    Delaware
    Tire pressure makes a big different in both gas milage and handling.
    Check it every week or two. 38 psi is a good setting.
    Also consider resetting your mass airflow sensor.
    It really sounds like yours is either not calibrated right or clogged up.
    Someone may need to correct me on this one but I believe you remove the negatvie wire from the battery and let the car sit like that for 30 mins.
    I average about 19.5 with mixed driving.
    Feb 24 2004
    Victoria, MN
    My mass airflow sensor went bad and after I replaced it I went from 19MPG to 20.8MPG average.... something is definitely messed up somewhere....
    May 09 2004
    What should i try? Should i unplug my negative battery sensor and let it sit? Should i go to the dealer?
    13 MPG is not alright. i gotta do something about this.
    Registered Member Three Rings QuattroCoryG's Avatar
    May 10 2004
    Silver 98.5 Audi A4 1.8TQ
    St.Louis, Missouri
    how does how much air you have in your tires effect gas milage?
    Veteran Member Four Rings illusive45's Avatar
    Feb 13 2004
    2009 Audi R8 - Gated Manual V10 | Former: 2006 A6 Avant 3.2:: Techno|Premium|Cold Weather
    SF Bay
    I have been averaging between 17-22MPG, depending on how hard I drive. I have a frequent lead foot, but I usually get to top gear as soon as possible when I reach highway speeds.
    Tire pressures have a lot to do with mileage. When a tire doesn't have enough air, it has more resistance. More air, less resistance. Its simple physics, fellas. Keep your tire pressures above 36 at the least.
    2009 Audi R8 V10 Gated Manual Sepang Blue, Tuscan Brown interior, Carbon Sigma Sideblades, Carbon interior, Stasis tune, Stasis exhaust, JRZ RS Pro 3 coilovers, HRE P40SC 20" wheels
    Former:2006 Audi A6 Avant 3.2:: Atlas Grey|Black leather
    2000 Santorin Blue S4 6MT , 1999 Volcano Black A4 1.8TQM, 1992 Sentra SE-R
    Track Weapon:: 2004 BMW M3 6MT
    May 09 2004
    14.6 MPG!! half tank left with the fuel injector cleanser.
    Perhaps does the remus muffler/exhaust system have to do with it maybe?
    May 13 2004
    2000 S4
    Delaware
    Go to the dealer and tell them something is wrong with your maf.
    They should be able to make everything hunky dory.
    Pulling the negative battery terminal is not really the best thing to do because it will cause a low voltage fault and may raise some suspicions that your car is chipped and you're swapping out ecu's.
    Drowning is my third favorite way to die.
    May 09 2004
    "maf" is that short for manifold?
    Veteran Member Four Rings bitterchild's Avatar
    Feb 16 2004
    audi is chit
    mass air flow as in mass air flow sensor. You may need to check you tuneup schedule. Also the tire pressure. You do realize at speeds above 55mph or so using a/c is more fuel effecient than cruising around w/ your windows down.
    concours show prep in the DC metro area
    turbos, rods, pistons, clutches, etc.
    May 13 2004
    2000 S4
    Delaware
    Sorry maf is Mass Air Flow sensor.
    You could have a bad maf or it just needs to be reset.
    What year is your car?
    2001.5 S4
    It plays a part in the car's "rolling resistance".
    When the tire is more flexible, there is more friction against the road, more effort is required to roll them and more kinetic energy is converted to heat and sound.
    Rolling Resistance from Tire Rack's website
    A vehicle's fuel economy is the direct result of its total resistance to movement. This includes overcoming inertia (Newton's Law), driveline friction, road grades, tire rolling resistance and air drag.
    During stop-and-go city driving, it's estimated that overcoming inertia is responsible for about 35% of the vehicle's resistance. Driveline friction is about 45%; air drag is about 5% and tire rolling resistance is about 15%.
    Overcoming inertia no longer plays an appreciable role in the vehicle's resistance during steady speed highway driving. For those conditions it is estimated that driveline friction is about 15%; air drag is about 60% and tire rolling resistance represent about 25%.
    May 09 2004
    Alrighty, first things first. I go outside today and grab a tire gauge. Each tire is 32 psi or under. I go to the nearest 76 station and fill each tire up to 36/37 psi. On my ride home my mpg dropped from 14.5 to 14.3.
    Tomorrow i will head over to Audi and ask about the Mass Air Flow Sensor. Should i have it replaced or reset? Is it covered on warranty?
    May 09 2004
    my car is an early edition 2001. I jsut bought it certified about 2 months ago
    2001.5 S4
    Warranty Extension for Mass Air Flow sensor
    Your car is certified, but in case anyone here has problems with their MAF sensor, Audi has extended their warranty for mass air flow sensors to 7 years or 70,000 miles, whichever occurs first, from the vehicle's original in-service date. Or if you've previously paid to have yours replaced, you can request reimbursement from Audi.
    Subject: Warranty Extension LR
    Mass Air Flow Sensor Warranty Extension for:
    - 2000-2001 Audi A8 4.2L Vehicles
    - 2000-2001 Audi A4 1.8T Vehicles
    - 2000-2001 Audi TT 1.8T Vehicles
    - 2000-2001 Audi A6 and S4 2.7L Bi-turbo Vehicles
    Dear Audi Owner:
    As part of Audi's commitment to our encironment, we would like to inform you of our decision to extend your Emissions Control Systems Warranty for a mass air flow sensors to 7 years or 70,000 miles , whichever occurs first, from the vehicle's original in-service date.
    The vehicle's original in-service date is defined as the date the vehicle was delivered to either the original purchaser or the original lessee; or if the vehicle was first placed in service as a "demonstrator" or "company" car, on the date such vehicle was first placed in service.
    The mass air flow sensor is an important emission control device which, in the event it malfunctions, causes the MIL light on your instrument panel to come on and may adversely affect the drivabliity of your vehicle. For additional information concerning your Emissions Control Systems Warranty, please consult your WArranty Booklet or your dealer.
    If the mass air flow sensor in your vehicle malfunctions, your Audi dealer will replace it without charge, as long as the vehicle remains within the above time and mileage limits.
    Please keep this letter with your Warranty booklet and deliver it to any new owner, along with the Owners Manual.
    If you have previously paid for the replacement of the mass air flow sensor, the enclosed ofrm explains how to request reimbursements. We would be pleased to review your reimbursement request.
    We are pleased to offer this extended emissions warranty and hope that you will continue to be a member of the Audi family. Thank you for driving an Audi!
    Sincerely,
    Marc R Trahan
    Director, Audi After Sales
    Warranty Extension for Mass Air Flow sensor - AZ Audi link
    Feb 29 2004
    2000 Audi S4
    San Diego
    how do u check ur gas mileage? sorry im a newbie
    May 13 2004
    2000 S4
    Delaware
    Hope all goes well for you.
    Just have the thing replaced.
    Apr 21 2004
    2013 S4 6MT, 2011 Escalade
    Coopersburg, PA
    Take the miles you drove divided by the gallons it takes to fill up your tank.
    2013 S4 6MT // sport diff // B&O // Phantom Black // Black Leather and Black Alcantara
    Feb 24 2004
    Victoria, MN
    Think about how hard it is to push a car or pull a trailer with a flat tire.... low tire pressure has the same effect, just not to that extreme...
    Feb 24 2004
    Victoria, MN
    "Alrighty, first things first. I go outside today and grab a tire gauge. Each tire is 32 psi or under. I go to the nearest 76 station and fill each tire up to 36/37 psi. On my ride home my mpg dropped from 14.5 to 14.3.
    Tomorrow i will head over to Audi and ask about the Mass Air Flow Sensor. Should i have it replaced or reset? Is it covered on warranty?"
    They covered my mass airflow sensor outside the factory warranty, I think this is a common failure and they are taking care of it.. If they try and make you pay for it push them harder.
    May 09 2004
    WELL -- Right now my tires are good and drove to Santa Barbara. Now I am at 16 MPG. But that is just because i was driving fast. (BTW i made it home in 51 minutes according to the audi timer.) But tomorrow i am going to AUDI d and get my mass air flow sensor replaced! TO BE CONTINUED...
    Feb 13 2004
    SF Bay
    Oh boy...OK, on your next fill-up, reset your trip odometer. Drive the car until you need gas and fill the gas tank again. Divide the total mileage from the trip odometer by the amount of fuel you added on that fill-up. Shaboooya! You got your gas mileage.
    Veteran Member Four Rings Hassmeister's Avatar
    Feb 12 2004
    2015 GOLF R APR Stage 2
    Re: Gas Mileage...
    Get a 1.8t A4 and mod it like I did. I get 34 HWY.
    S4 and gas mileage... somehow the two don't go together.
    Click here for AMSOIL - Superior Protection!
    Wholesale pricing and delivery to your door - ask me how!
    May 13 2004
    2000 S4
    Delaware
    Re: Re: Gas Mileage...
    My S4 is actually quite decent on the Highway.
    The problem comes in stop and go traffic. That just absolutely kills gas mileage.
    I average about 19.5 mixed, sure it's not the best but it is just about how much I got with my old '97 BMW 5 series and my S has way more power.
    If you're not flooring the car at every stop then you shouldn't be getting less than 17mpg otherwise something is definitely wrong.
    On 2000's and early 2001's the Bosch MAF's go bad a lot.
    Account Terminated Four Rings 10SecS4's Avatar
    Feb 12 2004
    00 S4x1.5-00 A6-03 RS6-07 SRT8
    I recently purchased a pretty well beat up red 2000 Tiptronic S4. I got an excellent deal on it and am using it as a daily beater right now.
    Anyway, according to the trip computer, I averaged 21 to 21.5 miles per gallon on the way back from the casino last weekend where I was doing an easy 75-80 MPH. Does that sound about right? I was thinking it was pretty low until I checked some of the other responses on this thread...
    Registered Member Two Rings Jooce's Avatar
    Apr 23 2004
    Arizona
    I drive in 6th gear any chance I get. According to the Real Time Gas meter, I'm getting roughly 32 mpg in 6th @ ~45mph. ~38mpg in 6th at about 65mph. Its the stop & go driving part get sucks... car eats gas until you get it in at least 4th gear. Otherwise i'm in the 15-22mpg range.
    May 09 2004
    But i cant even get above 15.9. I drove to Santa Barbara going 100-120 and the most MPG i got was 15.9--my peak. Usually im down in the low 14's around So Cali.
