Results 1 to 22 of 22
    May 26 2004
    indy
    problem with cigarrete lighter
    hey all, was wondering if someone could help me out... my cigarette lighter does not work at all...i replaced the fuse so i thought it would work but no dice ... also if anyone knows where i can purchase the whole housing again for real cheap that would be awesome...
    Feb 24 2004
    02 S4 & 67 Goat
    So Cal
    I dropped a coin in mine and it started zapping. I had to take it to dealer to fix it. sorry cant help.
    May 20 2004
    More cars
    Never Land Ranch
    I never use mine(i don't smoke nor will i ever let anyone do so in my car)
    SEXICAN
    2013 Q5 3.0T-DD
    2002 Honda Civic
    AMD/EPL Tial 605 B5 S4 SOLD
    Feb 24 2004
    02 S4 & 67 Goat
    So Cal
    me neither, I use it to charge my phone though so I never have the lighter in it. Coin just fell in.
    May 20 2004
    More cars
    Never Land Ranch
    doyou keep your coins in the little try right behind the cig lighter?
    SEXICAN
    2013 Q5 3.0T-DD
    2002 Honda Civic
    Account Terminated Four Rings MR VTEC's Avatar
    98.5 Audi 1.8TQM
    Brooklyn
    off topic: my ash tray is stuck!
    May 26 2004
    indy
    cigarette lighter
    no i dont smoke at all, i need it for my radar detector and my phone charger...smoke inside an AUDI....HELL NO!!
    Veteran Member Four Rings Pureaudi's Avatar
    Jun 23 2004
    97 a4 1.8t
    San Jose
    if you wanna smoke go to a hooka lounge! awsome place!
    Feb 13 2004
    <> Posts: 9913
    I think there's a fix for that on AW in the tech area.
    -Theodore Roosevelt, 1907
    98.5 Audi 1.8TQM
    Brooklyn
    i know i have to tear apart the dash i'll wait until my car comes back from the shop.
    Feb 15 2004
    99.5 a4
    monroe nj
    my cigarrete lighter works.. but if i try to plug in something as a radar or any other device it doesnt work.. i dunno wuts the problem wit that...
    Feb 24 2004
    02 S4 & 67 Goat
    So Cal
    "doyou keep your coins in the little try right behind the cig lighter?"
    I keep my coins in that POS double cup holder box. My phone sits in the 'ciggerette box holder' behind the lighter.
    "off topic: my ash tray is stuck!"
    Its most likely a coin under it jamming it. get some thin wire, something like a coat hanger and hook them out. or take it to dealer, they replaced my whole ashtray even after fixing it.
    Registered Member Two Rings
    May 31 2004
    Key Biscayne Flordia
    Hah i smoke in my car . I wonder why nobody else smokes in an Audi? If it was a ferrari I'd still smoke in it , its just a car :p
    2.7T S4/silver/M6/stock
    Veteran Member Four Rings VTAudiA4's Avatar
    Oct 20 2007
    Re: problem with cigarrete lighter
    Im resurrecting this thread to get an answer to the question. My cig lighter doesn't work either. I dont smoke but yesterday I bought a gps (mio c230) and when I plugged the adapter into the cig lighter it did not work. The car was on, the light turned red, and everything. Im leaving for a trip on Monday and the battery is only good for 3 hours.
    Veteran Member Four Rings .Mad Hatter.'s Avatar
    May 07 2007
    damn Audis, mine doesnt work either but im not sure if its the lighter itself or the housing...
    Veteran Member Four Rings audisnapr's Avatar
    Jun 06 2004
    2005 Ford E350 4x4 Sportsmobile, 1990 Corrado w/ VR6 swap track car, 2017 Mazda CX3
    does the cig. lighter work with the factory lighter? I found that a lot of chargers that plug into the lighter hole don't fit correctly and won't charge. I know the lighter in fact works, BECAUSE I SMOKE, but there are several accessory chargers that don't seem to connect correctly in the lighter. Sometimes I have to wiggle them around to get a good connection and other times they just don't work at all.
    Veteran Member Four Rings t1demont1's Avatar
    May 08 2007
    1999 1.8tqm gt3071r
    Orlando, FL
    yeah i gotta play the wiggle game too if i need to use my phone charger
    BetaAlphaTau Member #40
    1999 2.0 hx35 dbw conversion
    Oct 20 2007
    Yeah I wiggled the charger around too and it still didnt work and I also tried putting in another charger in and that one did not work either.
    Veteran Member Three Rings generik777's Avatar
    May 12 2007
    1998.5 A4 2.8 Quattro Tip
    MN
    I bought an adapter off ebay that's meant to plug into your existing lighter so you can have two things plugged in at once. Then I stripped the wires and hooked it up to the 75x terminal behind the dash. Now I have three working cig plugs. I put the dual one in that empty space on the floor behind the center radio console so it can't be seen. I have my sat radio and iPod thing plugged into it so they turn on and off with the car. Works pretty good.
    Veteran Member Three Rings devmaster's Avatar
    Sep 12 2007
    '00 A4 1.8tQM-S,'95 Subaru Leg
    Quote Originally Posted by audisnapr View Post
    ...BECAUSE I SMOKE,...
    thank god, i thought i was the only 1 who did on here..
    anyways audi PLEATHER repels smoke, my car never smells for some reason
    00 santorin blue B5 1.8tqm,
    its got stuff in it
    (mostly junk)
    Oct 20 2007
    Problem solved. Don't ask how because I really don't know how it started working again. It just did.
    Oct 30 2006
    B8 A4 Avant 6spd
    Re: cigarette lighter
    Quote Originally Posted by lpeezy View Post
    +1, mine is a permanent slot for my V1.
    -18 718 GTS
