Results 1 to 20 of 20
    Veteran Member Four Rings AsianA408's Avatar
    '10 A5 S-line, 07 Sline A4, 99 A4q, 2002 S4,2000 S4, 2008 335i
    San jose, CA AXION BETA
    first car issue in a while...
    ok im a 99 2.8 tip.
    im driving normal either up hill or flat road with RPMs from 1,500 to 2,500. and sometimes the car shutters on me and feels like its losing power for a split second and regains power again. im at 72k and havent done my timing belt yet if that really matters. does this sound like an engine issue? or a tranny issue? any help would work guys. ive been on this board for a while and this is the first issue in a long time.
    1999 audi a4q(Sold)
    2007 B7 S-line A4(current)
    2002 B5 S4 Santorin / 06 Ninja ZX-10R
    _________________________
    |.....Overnight.......................|.|\
    |........PARTS FROM........-....|.|||";,__,
    |_...__...JAPAN_______=====|.|_|..|...|
    "'(@)'(@)""'''''''"'''''''l''/(@)(@)*****(@)"
    TEAM|AXION
    "Are you a good sticker putter?" - Dino/S-POWER
    Feb 13 2004
    1999.5 Audi A4 1.8TQM, 1993 Eunos Roadster
    San Mateo, CA
    Check your engine oil levels and do an oil change. I had the same problem in my nissan, it was running without engine oil for a while then the engine blew.
    1999.5 1.8TQM | 2003 Porsche Boxster S | 2004 Kawasaki ZX6RR | '92 & '93 Mazda Miata
    DBC ownz JOo!
    Veteran Member Four Rings A4_Andre's Avatar
    Feb 13 2004
    99.5 Audi A4 2.8Q Tip
    Staten Island, NY
    could it be a misfire? coilpacks, spark plugs, wires? my car misfired when i needed a new engine temperature sensor also.
    Veteran Member Four Rings Devious27t's Avatar
    Mar 02 2004
    2001.5 S4 Avant on Corn
    Orange County
    if it were coilpack the check engine light would be blinking... how long has it been since you have changed your plugs i would recommend doing that before you jump to any major conclusion, your description happens very commonly with fouled plugs.
    Active Member Four Rings
    Time for a VAG
    so you guys suggest changing the plugs? i know my MAF sensor is shot to hell. if that has anything to do with it. it was when i was installing my intake.
    1999 audi a4q(Sold)
    TEAM|AXION
    Registered Member Three Rings aborchew's Avatar
    Feb 25 2004
    '98 Audi A4 2.8QM
    Chicago, IL
    It can't hurt to do the timing belt either, if that goes you're going to be paying for a lot more than a new timing belt.
    Registered Member Two Rings koolAsiCE's Avatar
    Feb 26 2004
    Alfa Romeo 147, Audi A4 1.9TDi Quattro
    England, London
    change the belt, plugs and water pump to be on the safe side.
    Veteran Member Four Rings maxh2o's Avatar
    Apr 13 2004
    B5S4,C2avant,Cgt,UrQ
    San Francisco
    Sounds like a misfire John, I say get your plugs changed and if that doesn't help, get VAG'd may be something else like your trindle switch.
    And since you have a 2.8 do you know if you have a timing belt or Chain? I had a chain on my old 90sport 2.8 which you really don't have to worry about. If you've got the belt, change it ASAP! ANd get the pump done to be on the safe side.
    You going to ALMS at all? And although I'm clearly in no hurry, any chance of me getting my stocks back sometime? pm me.
    http://www.audizine.com/gallery/data...70780_copy.jpg
    Dominating the fast lane since 1984.
    Veteran Member Four Rings audidood's Avatar
    56 Oval, 2017 Tacoma
    san diego, ca
    kinda pushin your luck with 72k on the orig. timing belt.
    2004.5 USP A4 1.8t with mild mods.
    1956 VW Bug with major mods.
    Registered Member Four Rings jesseahhstyle's Avatar
    OC, California
    My timing belt slipped at 71k with my 1.8t. *previous owner* IIRC w/ the 2.8 they are ment to last longer I want to say I read somewhere saying they usually last to about 90k
    I was having that problem a little bit but since i replaced my battery its gone. But as what everyone said before check the spark plugs -- plus if your MAF is dead that will throw off alot of things if you are not getting the right amount of Air/Fuel mix your car will sputter like its doing.
    Feb 13 2004
    San Mateo, CA
    what everyone else said. Also borrow someone's working MAF and test it with your car.
    DBC ownz JOo!
    Feb 25 2004
    '98 Audi A4 2.8QM
    Chicago, IL
    I'm also a '98 2.8 and it's definately a timing belt, not a chain.
    Feb 13 2004
    San Mateo, CA
    why couldnt AOA have spent a few more cents for a chain insttead of the age old belt!
    DBC ownz JOo!
    Registered Member Three Rings awe4rings's Avatar
    Feb 18 2004
    Fairfield County, CT
    Keep production cost lower so people can more easily afford the lowest line of car they sell. Diversify their overall market if you will.
    -awe4rings
    Veteran Member Four Rings A4 in SC's Avatar
    Feb 16 2004
    '84 911 Carrera GP White, Burgundy cloth
    Simpsonville, SC
    Anyone w/ a VR6 VW can answer that question - the chain isn't fool-proof either. They are known for stretching over time. They actually stretch more than a belt. I'd much rather pay for a belt than a chain... price them - you would too. See what I mean?
    Feb 13 2004
    San Mateo, CA
    My Audi is having its mid-life crisis right now. You know...all that expensive Euro maintenance woo's.
    DBC ownz JOo!
    ok im gonna go take care of the 75k service then. just to be safe then sorry.
    1999 audi a4q(Sold)
    TEAM|AXION
    would it be the plugs tho?
    1999 audi a4q(Sold)
    TEAM|AXION
    Veteran Member Four Rings bitterchild's Avatar
    Feb 16 2004
    audi is chit
    plugs or maf. TB would not have any bearing on the problem you've described. You should check for some soft codes. If there is a random misfire or one only under heavy load (hill climb @ low rpm) it may not be enough to trigger a CE light but it will store it for a few days. Improper maf signal, bad plugs, partially shorted plug wires can all be causes. Coil packs are unlikely to be causing such a low frequency issue. Just pull your plugs and your diagnosis will be that much easier.
    concours show prep in the DC metro area
    turbos, rods, pistons, clutches, etc.
