Results 1 to 10 of 10
    Feb 12 2004
    99.5 1.8T A4
    Cleveland OH
    Cadmium vs. Zink plated rotors!
    Which holds up better?
    There is cadmium and there is zinc plating. The zink plating is awailable in silver, gold, and black........is there a difference onther then color?
    Registered Member Four Rings jesseahhstyle's Avatar
    OC, California
    Cadium never rusts from my understand dont know much about the zinc Thats just my understanding. They also do the cadium in different colors also.
    Feb 17 2004
    Sterling, VA
    Zinc wash is a very weak anti-corosive coating. Many tool and hardware companies coat bolts and tools in zinc plating to make them "rust-proof" but, they only stay that way for a couple years.
    I'm sure many of your read that and said "So what? A couple of years is long enough." The key here is that brake rotors get hot and then cool down hundreds of times in a year. THis accelerates the zinc breakdown process. In turn Zinc plating lasts only for a few months before it begins to pit and flake.
    Cadmium plating is always the way to go. It's much thicker and it will adhere to metal surfaces much better than Zinc. Cadmium won't always stay bright and shinny but, it will always stay rust free.
    Brett - Moderator
    Issue?: email me.
    _____________________
    Stage 3 2004 A6 2.7T 6M
    Feb 12 2004
    99.5 1.8T A4
    Cleveland OH
    so how long does it take for cadmium to wear away?
    Feb 10 2004
    2009 A4 2.0T Sedan
    Cadmium = rust free = good!
    Don't know that much about the zinc, but the above info sounds pretty accurate.
    Registered Member Three Rings widm3r's Avatar
    May 02 2004
    LI, NY
    and also if you get it in different colors is it anodized then the outer coat or what and does the color chip away or from weather or does it just wear down like the regular color?
    Widm3r
    Feb 17 2004
    Sterling, VA
    The first set of cad plated rotors I had on any of my cars were made by Powerstop. They were on the car for about a year and a half. They were rustless the day I threw them in the trash can (they were warped by then).
    My ECS Slotted/Plated rotors on my A4 stayed clean the whole time I had them. About 1 year. I know they'd stay rust free much longer but, the slotted parts wore out too soon. Those rotors were crap. The plating was good though.
    Brett - Moderator
    Issue?: email me.
    May 02 2004
    LI, NY
    And also http://www.tantrumwerks.com/ sells rotors by Disc Brake Australia, never heard of them, does anyone know if they are good?And also what do you recommend flat rotors or slotted or cross drilled or both?
    Widm3r
    Feb 12 2004
    99.5 1.8T A4
    Cleveland OH
    so basically the zink plating won't last at all?
    Senior Member Two Rings BuffysRS4's Avatar
    Jun 12 2004
    Audi A4 1.8T, Audi Q7 3.6 Prem
    Markham, ON - Eastvale, CA
    Lightbulb
    I hate to burst everyone's perception about cadmium plating but it does not prevent rust as well as everyone thinks. I have x-drilled OEM Brembos cad plated on all four corners and am very disappointed at the color they are now, brownish red with speckles of silver. Cad plating isn't all that it seems. I'm just waiting to wear these out enough so that i can go BIG.
    "Speed kils, drive better"
    2007 Audi Q7 3.6 Premium
    2004 Volvo XC90 T6 AWD (TRADED POS)
    1999.5 Audi A4 1.8TQM
    1996 Mitsubishi Montero LS
    1993 Geo Storm SiR (RIP)
    1992 Mazda 323 (RIP)
