Results 1 to 7 of 7
    Registered Member Three Rings
    Jul 13 2004
    san diego
    Talking Tubro question...NEEEEDDD HELPPP!
    well to make a long story short, i blew my turbo yesterday an took it to the shop for them to tell me wut i knew.... SO NOW ITS TIME FOR MY KO4
    but ive been lookign at either the awe kit an the ecs an i have a few questions, well first off the awe comes with software and the ecs doesnt, does that mean ill need to get it or will i just not get as much power as i would with the software, and second question is that i kno with the awe ill need the new exhaust but if im not running as powerfull as the awe an im uisuing the ecs will i still need the exhaust..
    i think that made sence as u can tell im young an a noob, so bare with me
    thank you
    ~mdp~
    Feb 13 2004
    <> Posts: 9913
    1) The ECS kit is not really a "kit". It's just the turbo and hardware.
    2) For a full K04 upgrade, you'll also need a) larger injectors, or b) a 5 bar FPR.
    and you'll want the software. If you don't planning on getting the FPR/injectors and software, then I would say it's really not worth it.
    I think you should definitely opt for the AWE kit if you can float the cash. You'll also want the exhaust to compliment the added flow.
    -Theodore Roosevelt, 1907
    Veteran Member Four Rings MKGIY's Avatar
    2012 S4, 2012 GMC Acadia
    New Jersey
    You are better off getting the program and then getting an exhaust done the road. You will not benefit from runnign a KO4 with KO3 software, atleast not to the fullest potential.
    Mike
    Jul 13 2004
    san diego
    Thanks a bunch, do u have any good aka cheep sites for injecters, also would it be ok to get the exhaust later on because i cant aford it now buit i need a new turbo now
    one point eight tee
    Awaiting Confirmation Four Rings
    Feb 12 2004
    Albany NY
    Click here im selling mine its brand new!
    Jul 13 2004
    san diego
    i gota 99 tip quattro so itll fit mine, an when u said giac ecu u mean the whole ecu or juss the chip for the ecu?
    one point eight tee
    New Jersey
    He has the chip on his ECU so you guys would have to figure something out cause I dont beleive you can switch yoru ECUs.
    Mike
