Results 1 to 14 of 14
    Registered Member Two Rings
    May 31 2004
    cal
    Magnaflow Exhaust Sound
    Hi,
    Anyone knows how the magnaflow exhaust or muffler sounds?
    Veteran Member Four Rings astris's Avatar
    Mar 03 2004
    nothing
    San Diego
    Lon does...
    He has a custom setup and if I remember correctly it was Magnaflow. I heard it in person the other day and it sounded pretty damn good. Nice low, deep tone. Didn't ride in the car, but I really liked the sound, not too loud.
    Veteran Member Four Rings Villains's Avatar
    2003 and 2006 Audi A4
    Woodland Hills, CA
    I had a magnaflow exhaust on my Mustang. It sounded great and was a good quality piece. I know this doesn't tell you much about how it sounds on an Audi, but I can tell you that they are quality systems.
    -Derrick
    It will be nice working with proper villains again!
    - Basher (from Ocean's Eleven)
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Re: Magnaflow Exhaust Sound
    Originally posted by titan
    Hi,
    Here is my car on the dyno, it has a full 3" exhaust with a single in single out magnaflow muffler.
    dyno run of 335 at the wheels on 91 octane and 16psi
    This is a untuned run just after putting the car on they dyno. Just wanted to see what it was making before we even started tuning. The run is from 3k rpms to 7300 rpms and the shift light comes on at 7k. The hp peak was at 7300. After all the dyno tuning I had them change the rev limiter to 7800 which is where my power still peaks at while running 20psi 105 octane.
    Veteran Member Four Rings HyperM3's Avatar
    Mar 20 2004
    Lawrenceville, NJ
    Thermal systems are magnaflow mufflers just FYI.
    21 S5 Coupe - RacingLine strut brace/034RearSwayBar/CTSTransMount/034 tune/VPS Res Delete/CTSIntake
    10 S4 (gone),13 S6 (gone),14 S6 (gone),14 S6 (gone),16 S6 (gone),17 A4 (gone),19 S4 (gone)
    20 BMW R1250RS
    ACNA Lifetime Member - 26690
    Respond to a post with an answer, they will keep asking questions. Teach them how to RTFM, they will learn to help others.
    May 31 2004
    cal
    Iam deciding on either the remus exhaust but the magnaflow is probably cheaper, just wanted to know the sound difference between these to.
    thanks for your input. which one sounds better and is louder?
    Mar 03 2004
    nothing
    San Diego
    Hmm... I haven't heard the Thermal in person, just the clips. Lon's Magnaflow setup is much quieter than the Thermal. He will be able to tell you much more than me. Maybe he can chime in.
    May 31 2004
    cal
    so thermal are magnaflow? I just wanted to know how much louder they are from the remus exhaust or do they sound similar. The remus are quite expensive for just the muffler but made well.
    May 31 2004
    cal
    I would like to know the stock # on the magnflow muffer if anyone knows.
    I went to audiworld and search for magnaflow sound and they was a sound clip and it sound good , anyone heard it on audiworld?
    thanks guys for your help
    May 31 2004
    cal
    if anyone can tell me which magnaflow muffler it is?
    the race ss muffler or universal?
    thanks
    Mar 03 2004
    nothing
    San Diego
    Pm Lon (aka Bugzy). I'm sure he wouldn't mind helping you out with some info.
    03 A4 Avant, 85 ABA Golf
    Palo Alto, Ca
    Re: Re: Magnaflow Exhaust Sound
    Damn your car is just nutty
    Active Member Four Rings
    Nice run.
    Senior Member Two Rings jab3style's Avatar
    Mar 18 2004
    03 1.8t/ 04 Armada LE
    NorCal
    ok. Just got the magnaflow intalled today. After install, went to a GTG in orang'e county and met up with some cool dudes. I compared it with someone who had nuespeed and another with Thermal. The Magnaflow's sound was closer to the thermal.
    In the cockpit, I personally think its too loud for my taste buds but the other enthusiast @ the GTG approved of the sound. I had a few of them ride in the car and they both said it wasn't too loud and it was fine. As far as performance, It definately put a smile on my face. Car felt livelier on higher rpm ranges. From Launch, the Butt-dyno definately approves. Hard to estimate on hp gains so I won't even go there but, definately gains.
    I had a guy drive the car WOT while I listened from the outside. Wow, sounds Amazing. deep melow tone (hard to believe its a 4 banger..hehe)
    I was initially the 1st fwd b6 to have the thermal. Let's just say I couldn't wait any longer. I did some research on the forums on custom exhaust and a few names came to mind and also the fact that the cost was much much cheaper for about the same performance and looks. So I inquired about a full exhaust set up at a place around the corner from my house. Bam! Magnaflow. Stainless steel mufflers(looks just like thermals) and picked the tips that look just like our stocks but now 3.5 inch in diam.
    Overall scale 1-10. Ill give this an 8 only because it's a bit too loud for me. But I can always install a resignator to lessen the sound. Then It might be a 10.
