Results 1 to 12 of 12
    Seattle/Seoul
    java programming help...
    i have this for loop:
    for (int i = 1; i <= 10; i++) {
    System.out.println(i);
    and want to:
    Show a revision of this code that counts from 1 to 10 but skips the number 7. Don't use more than one loop.
    i'd appreciate any help
    thanks
    peace
    DBC ownz joo!! <- Wow what year is that from??
    Veteran Member Three Rings voodooA4's Avatar
    how about:
    for (int i = 1; i <= 10 && i != 7; i++)
    (That for loop is valid in C/C++ so I imagine it'd be fine in java as well, since they share a fairly similar syntax)
    98.5 Cactus Green A4 Quattro, APR Chipped
    114K Miles
    Open Source ECU: http://groups.yahoo.com/group/openecu/
    OpenDiag Group: http://groups.yahoo.com/group/opendiag/
    Seattle/Seoul
    hmmm... ran it in dr. java and it goes up to 6 and stops...
    thanks for the help tho, any other ideas to get it to just skip 7?
    also, in boolean arthimetic, what does: || mean?
    thanks
    peace
    d'oh! I shoulda known that...simple mistake. I'll figure out another version for you...
    anyway, in boolean algebra, you have three simple operators: AND, OR, and NOT (there's some others, but they're mixtures of these three)
    In C-style languages, they're written like so:
    AND is &&
    OR is ||
    NOT is !
    114K Miles
    Seattle/Seoul
    voodoo u rock!!!
    thanks so much!!!
    peace
    are you allowed to use an 'if' statement inside the loop? I can't think of a way to do it otherwise...except maybe XOR'ing the numbers with 7, but that seems too ridiculous for this case...
    if you're allowed to, then:
    for (int i = i; i <= 10; i++)
    if (i == 7)
    continue;
    else
    114K Miles
    Veteran Member Three Rings quicksilver_S's Avatar
    City that never sleeps
    try
    for (int i = 1; i <= 8 && i >=1; i++)
    that would only print the numbers 1 thru 8, no? unless I'm missing something...
    114K Miles
    Seattle/Seoul
    well doesnt say that i cant use an if statement so i think we are good to go using voodoo's 2nd attempt.... one correction tho: i think its supposed to be:
    int i = 1 and not: int i = i right?
    THANKS GUYS!! really appreciate the help!
    peace
    no problem!
    yep, it should be i = 1
    114K Miles
    Seattle/Seoul
    another question:
    if i'm supposed to evaluate a "boolean expression"
    how am I supposed to do:
    (x > 3) || z
    thanks
    peace
    what do you mean 'evaluate it'...how so?
    114K Miles
