Results 1 to 2 of 2
    Established Member Three Rings A Foore's Avatar
    Apr 07 2004
    '05 6spd TSX with NAVI.
    GO LEAFS GO! GO LEAFS GO! ...
    control arms/bushings question
    The control arms going bad is basically the bushings itself, correct? If so, then why do we have to replace the whole arm? Can't we just replace the bushings on the existing arms? Wouldn't that be a lot cheaper?
    97 1.8TQ
    GIAC / 710N / H&R Race / Koni yellows
    Feb 17 2004
    Sterling, VA
    Both the bushing and the ball joint fail on these control arms.
    The bushing is replacable but, the balljoint is pressed into the arm in a factory on a metal press. Definately not replacable by the average person.
    So, in essence, you need to replace the balljoint and bushings thus, the whole arm.
    Brett - Moderator
    Issue?: email me.
    _____________________
    Stage 3 2004 A6 2.7T 6M
