not only that, for anyone who has ever turned a rotor themseves would know it is difficult to get a consistent surface as the blade can potentially get stuck in the crevices and holes in the rotor... this could cause gouging around the slots and holes which would make for a warped braking surface. there are some that will turn them but most will not, i wouldnt do it personally but that is why i dont have cross drilled or slotted rotors.
Originally posted by turbo90awd
I don't see how you can cut a set of slotted/drilled rotors and make them useful again.
The slots are going to be 2-3mm deep on each side of the rotor. The drilled holes will need to be chamfered at the edges to make them work properly without tearing up the pads too much.
the stock thickness of an A4 front rotor is 25mm.
the wear limit on said rotor is 23mm.
how are you supposed to cut this slotted/drilled rotor without compromising the integrity of the rotor?
Are we saying that you would cut .5mm from each side and then re-slot/re-drill the rotors? Won't the slots be too shallow to be effective now?
