Results 1 to 4 of 4
    Apr 02 2004
    Boston
    What size spacers should I run with 245/40/17 in the rear?
    I'm looking to run 245/40/17 continentals in the rear on the stock avus rims and was wondering what size spacers I should use back there to clear the rear suspension and line up nicley with fender but not stick out too much. 5mm, 10, 15? BTW I know 245 are a bit wide for the stock rim, but the continentals are not that wide of a tire compared to say an S-03 so I don't think it should be that much of an issue. I would just get 235/40 avs sport or S-03s but I only need 2 tires as the fronts were replaced a few months ago and want to have 4 tires of the same brand, and I think 235 continentals wouldn't be that much wider than the fronts and it would be silly to have the rears only 10mm wider than the fronts.Thanks.
    01 Santorin S4
    RS4 Grille
    RS4 bumper mod
    Feb 24 2004
    02 S4 & 67 Goat
    So Cal
    I don't quiet understand your question. You are running a 235/40 cont. in the front and want to run a 245/40 cont. in the rear?
    Apr 02 2004
    Boston
    No, I am currently running stock size 225/45/17 on all tires but am going to switch to 245/40 in the rear and I am pretty sure I will need spacers for those. The front tires are just about new but the rears are worn so I would like to put wider tires in the rear for both looks and peformance. So with the new rear tires I will be running 225/45/17 front and 245/40/17 rear hopefully. Sorry for not being more clear.
    01 Santorin S4
    RS4 Grille
    RS4 bumper mod
    Feb 24 2004
    02 S4 & 67 Goat
    So Cal
    You know I don't really have any advice about your situation b/c I havnt dealt with that tire size or spacers. But to be honest not only are you asking for trouble about fitment and clearence, but also I dont think it is going to help performance. If I were you I would stick with normal size tires with the same all around, if you want to go wider go with a new wheel set up. Sorry I couldn't help.
