Results 1 to 20 of 20
    santa monica CA
    FS: Brabus mono5 replica 19inch
    Anyone want these wheels? 19x8.5 with +35 offset brabus monoblock 5 replica wheels made by moven. Comes with centercaps brand new never used silver with polish lip
    santa monica CA
    Registered Member Two Rings
    May 25 2004
    2004.5 A4 Avant 1.8T Quattro (Atlas Grey), 2002.5 Passat 1.8t(Silverstone grey)
    Vancouver, Canada
    how much u askin?
    Senior Member Three Rings quattroED's Avatar
    Apr 14 2004
    Pic doesn't work.
    <img src="http://www.audizine.com/gallery/data/500/1717mycar1sig.jpg">
    santa monica CA
    Let's try that again...
    and I'm only asking 950 plus shipping
    Veteran Member Four Rings Pureaudi's Avatar
    Jun 23 2004
    97 a4 1.8t
    San Jose
    nope still no worky
    santa monica CA
    okay let's try again..ONE MORE TIME!!
    Feb 12 2004
    ‘23 RS5 Sportback '20 Q8 S-Line
    are these audi fitment or MB? Do you have rings and lugs for them?
    santa monica CA
    They both have same fitment 5x112. It will fit all audis since it has audi bolt pattern as well as +35 offset. Will fit some MBZ but not the SUV one. I have hub rings I will include and I can include lugs as well.
    santa monica CA
    Originally posted by LAS
    have weight?
    I believe they are around 26 pounds...not bad for 19s? I donno..haha
    Veteran Member Three Rings Jazzman's Avatar
    Feb 12 2004
    Montreal, Canada
    I seem to remember that Pavant had these on his Avant and they looked pretty good.
    “Simplicity is the ultimate sophistication.”
    Feb 12 2004
    Pavant had the other splt spokes. Yes, they did look nice. Isnt there a fitment issue between MB and Audi?
    Active Member Four Rings
    The should fit fine with the right hubcentric rings. The only other issue I have seen with MB wheels is the diameter of the lug bolt openings. Usually MB ones are smaller.
    Feb 12 2004
    so they have to be redrilled? I guess my question is, since they are Moven, are they Audi fitment or Benz fitment?
    I had that problem with my Hagen wheels when I got them. Axis told me it was a common issue. I just drilled them out myself from the back. It was too easy to do. Those wheels should fit fine.
    santa monica CA
    These wheels do not require re-drilling. THey are Audi/Bens fitment with enough clearance to fit both... hence the no need for drilling. I will take 900 bucks... need money baaaad...
    EDIT: forgot to mention Brabus centercap is NOT included...I no longer have those...comes with a silver centercap that you can use or you can put a "MOVEN" sticker on it which is included. Pick ups welcome!! SHIPPING IS A OKAY!
    santa monica CA
    forrrrr ssssale
    santa monica CA
    Okay guys...900 obo...meaning I will take probably 860 or so.. I can accept paypal, cash, cashier's check, money order or even personal check if yo'ure local
    Veteran Member Three Rings pkancel's Avatar
    Apr 10 2004
    2020 BMW M340i, 2019 BMW 330i, 2015 BMW 328i
    Mission Viejo, CA
    Sent you a PM about an even up deal if you might be interested
    2017 BMW 540i / 2015 BMW 435iGC / 2017 Audi A3 Quattro
