Results 1 to 4 of 4
    Senior Member Two Rings xplosiveg06's Avatar
    Dec 07 2006
    few
    Anaheim Hills
    where to get soldering done???
    i need to get a new capacitor soldered in for my e36 m3s digital climate control and was wondering if anyone here knows anywhere to go that does soldering for a good rate?
    Senior Member Three Rings so.cal.sparky's Avatar
    Oct 12 2006
    Moorpark,CA-Ventura county
    Re: where to get soldering done???
    i can do it it is real easy
    -Chris
    Veteran Member Four Rings belinko's Avatar
    May 09 2005
    Audi 1.8T QM
    Encinitas, CA
    Yeah, go buy a soldering handpiece at Fry's or RadioShack and do it your self. It's not hard, heat up the end of the exposed wires add some tin and shrink tube/electrical tape to seal it up and you'll be good to go.
    If not, maybe a car audio shop could do it for you?
    1.8L, JE pistions, IE rods, APR stg3+, GT28 Turbo, Setrab, ER comp. FMIC, APR HFC, Milltek Cat-back, APR 91, 93, 100 - CM FX 300, CM 240 LWFL, JHM 4:1, AMS SS, RS4 Motor Mounts - 355mm Alcon 4 pot, 300mm Alcon S4 - Stasis/Ohlins MS, Hotchkis Front and Rear, Stern adj. CA Front, 034 adj. CA Rear - 18x8.5" Work CR Kai wheels, NT-01 & Dunlop Z1 star spec - RS4 Front bumper and grill, Tow Strap, RS4 E-codes - SPA Technique Dual Digital gauges Oil & Water temp, Oil & Boost pressure, RS4 Door Handles
    Veteran Member Four Rings A4TwoZeroT's Avatar
    Aug 03 2005
    San Diego, CA
    contact Agravic 2.0 (Ansen)
    good guy! expert in all electronics stuff
    his website is audimods.com
