Results 1 to 12 of 12
Thread: HID Fogs
    Veteran Member Four Rings lunamarA4's Avatar
    Feb 25 2004
    lots of tools and spare parts
    San Diego, CA
    HID Fogs
    Today I made the conversion from H11 to HIDs in my fog housing....
    I know many think its pointless but I did it and there is no turning back
    N e way.... the come on for 2 sec and turn off
    I was searching here and on audiworld and can't find the thread that discusses the solution to this problem
    Can anyone help please?!
    4 SALE B6/B7 parts
    RafE |2004 BT White A4 Avant|
    |2002 S8 6spd - fully overhauled + 6 spd|
    |1988 E30 S52 Pandem Kit|
    |1991 E30 M20 Touring|
    Feb 25 2004
    02 A4 1.8t BT / 03.5 M3
    B-more, MD
    what are details? what kit? how did you wire up?
    check your ground?
    02 A4 1.8T fwd
    Maestro tuned and built by RAI.... bottom end, some head work, 3071 for now, custom RAI FMIC, and bunch of other stuff that I gotta find receipts for.
    my gallery
    Mar 23 2004
    Boston
    what mcpath said is right..check all the wires..are they all connected and did you ground them correctly.
    I just installed HID fog yesterday, it work perfectly fine
    Veteran Member Four Rings CO AVANT's Avatar
    Feb 12 2004
    '03 B6 Avant, '15 B8 A4, '14 S8, '15 Duramax
    Everywhere
    Where does one get HID fogs? $$$?
    Registered Member Three Rings
    Feb 29 2004
    2005 Sebring S2000
    DubC, PA
    ot...but did you get my email about the taillight?
    Veteran Member Four Rings A4 - Oh Snap's Avatar
    May 03 2004
    Irvine, CA
    time for hid tail lights!!
    Feb 12 2004
    2002 A4 1.8T Tip/Q/Xenon
    Sacramento
    Did you install your projectors into your fog??? Check all the wiring. Make sure you have soldered the connections instead of just twist them together.
    To troubleshoot it, take it out and wire it directly into the battery using jump start cable and see if it stays on all the time. If it does then it is your connection or your fog wiring.
    Feb 25 2004
    San Diego, CA
    I swapped my OEM HIDs with ProtoColD
    4 SALE B6/B7 parts
    Feb 25 2004
    San Diego, CA
    I used my OEM projectors and modified the fog light housing :)
    4 SALE B6/B7 parts
    Feb 25 2004
    San Diego, CA
    Are you running oem or aftermarket intercooler?
    HOw did you fit the fog light on the driver side, I have no space with the oem?
    4 SALE B6/B7 parts
    Feb 25 2004
    B-more, MD
    well I had problem of them cutting off and it was a ground prob.
    02 A4 1.8T fwd
    my gallery
    Feb 12 2004
    Sacramento
    like I said, if your wiring does not have enough juice. You need to hook that up to the battery and run a relay to it for switching.
