Results 1 to 8 of 8
    Active Member Four Rings Ben@SpeedBarn's Avatar
    03 A6 2.7t, 00 GTI, 76 GMC
    Pittsburgh, PA
    Avant taillights...how do i get to them to change the bulbs?
    Also i have an 01.5...what steps are there to the dual foglight mod for that car?
    Thanks.
    O It's an s4 but figured it would be the same as the a4
    Registered Member Four Rings Zodiak's Avatar
    Washington DC
    I don't own an Avant but I assume it's not much different than the sedan. on the passenger side there should be 3 or 4 tabs at the back of the tail light in the trunk, twist them a little and pull the cover off. then take off the bulb holder and switch whichever bulb you need to change. To do the dual rear fog remove the 4 nuts holding the tail lamp in (10mm deep socket IIRC) then just pull the light out and drill/dremel out the blocked hole in the top.
    Pittsburgh, PA
    Yeah that is how my sedan was...not the avant though. Hopefully the fog mod will be the same.
    Veteran Member Four Rings A4_Andre's Avatar
    Feb 13 2004
    99.5 Audi A4 2.8Q Tip
    Staten Island, NY
    just want to say grats. i didnt know u got the S4 avant.
    Pittsburgh, PA
    Yep last saturday. I love her. But it's still hard parting with the a4. I was cleanin her all up to show some ppl that wanted to buy her and was remembering all the times we spent together...modding...driving....I almost cried.
    Forum Moderator Four Rings blacka4's Avatar
    Dodge RAM 1500
    Pittsburgh Area
    i love her too....haha even though shes yours...shes a wonderful piece of german engineering
    -Rob - Moderator - PM Me!
    RIP:1999.5 Audi A4 1.8TQ Tip Brillant Black
    2009 Dodge RAM 1500 Crew Cab Sport - AZ Plate Frame - Bone Stock otherwise
    2014 Jeep Grand Cherokee Summit
    Veteran Member Four Rings 4ingDrive's Avatar
    Feb 25 2004
    Chi town burbs
    The avant tailights are held in with 10mm bolts as well. Mine came out pretty easy. First you have to pull the jack out to make some more room. I used and airsaw and a rattail file and it took a hole 5 minutes.
    99.5 A4 Avant
    always some shit broken
    Pittsburgh, PA
    Sweet i'll pull the jack out and take a look! I really didn't want to have to pull the carpet out or anything.
    Another question. Has anyone ever seen pics of the sub in the avant. I would like to see what it looks like but don't want to rip the trunk apart.
