Results 1 to 23 of 23
    May 20 2004
    More cars
    Never Land Ranch
    What is my redline?
    As far as i can tell on my tach., the redline is at about 6200rpm. My car is chipped by APR. Does the APR chip raise my redline? If so, to what?
    SEXICAN
    2013 Q5 3.0T-DD
    2002 Honda Civic
    AMD/EPL Tial 605 B5 S4 SOLD
    Orange County, CA
    just bouce it off the redline in 2nd gear, and youll find it. it wont hurt anything the rev limiter is there for a reason. then you'll know where your limiter is and you can adjust accordingly.
    B5 Parts For Sale
    1999 A4 1.8TQ
    San Jose, Ca
    bounce? doesnt a chip remove your rev limit? or was that your speed limit. Or both? I revs close to 7k and thats dangerous enough for me. Screw this wait till it bounces business. ;P
    Orange County, CA
    it doesnt remove the rev limiter, it moves it up like 200 rpms, nothing drastic, and it removes your governor that is at 127 or 128 or something. you cant over rev the car, itll hit the limiter and kick the rpms down a little, in case you somehow forget to shift. haha. it wont hurt it though, just dont drive around bouncing it off the limiter all day. you gotta shift sometime you know.
    B5 Parts For Sale
    May 20 2004
    More cars
    Never Land Ranch
    cool, i didn't know that our cars had a rev limiter. Always find out something new
    SEXICAN
    2013 Q5 3.0T-DD
    2002 Honda Civic
    May 20 2004
    More cars
    Never Land Ranch
    What is the rev limiter set at? Before i try it
    SEXICAN
    2013 Q5 3.0T-DD
    2002 Honda Civic
    1999 A4 1.8TQ
    San Jose, Ca
    NOW you tell me.
    Veteran Member Three Rings voodooA4's Avatar
    I think its originally at 6500 or 6800 RPM, the chips usually put it to 7100 if I recall correctly...
    98.5 Cactus Green A4 Quattro, APR Chipped
    114K Miles
    Open Source ECU: http://groups.yahoo.com/group/openecu/
    OpenDiag Group: http://groups.yahoo.com/group/opendiag/
    Orange County, CA
    yea, i think its around 6800 stock as well.. chips make it 7100 or 7200. although its still not really beneficial to rev that high when driving, i think you get the most power when shifting lower where the redline starts.
    dukez.. what does that pic have to do with anything?
    B5 Parts For Sale
    Active Member Four Rings ECA4's Avatar
    Feb 14 2004
    New Jersey
    Does this also apply to Tiptronics? If I let it rev in 2nd gear without upshifting will it hit the revlimiter or is that only on manuals?
    1999 A4 1.8TQ
    San Jose, Ca
    The picture means the car blew up because someone didnt shift.
    Orange County, CA
    you can put it in tip mode and never touch the shift button, it will shift for you if you hit a high enough rpm.
    B5 Parts For Sale
    Veteran Member Four Rings Ryan S.'s Avatar
    Texas
    it doesnt look like it blew up. it looks like it hit a pole of some sort.
    God Bless America!
    1999 A4 1.8TQ
    San Jose, Ca
    Yeah well thats what happens when you make a pole mad.!!!
    May 20 2004
    More cars
    Never Land Ranch
    yeah cause poles has a tendency to just move and slam itself into cars, tricky poles.
    SEXICAN
    2013 Q5 3.0T-DD
    2002 Honda Civic
    Veteran Member Four Rings Devious27t's Avatar
    Mar 02 2004
    2001.5 S4 Avant on Corn
    Orange County
    be careful with downshifting as they dont have a downshift rev limiter... wrong gear=boom not rev limiter
    May 20 2004
    More cars
    Never Land Ranch
    When you say downshifting, do you mean dropping down a gear, and letting the rpm's rev up or letting the rpm's rev down? Cuase i wouldn't see the difference if downshifting rather than upshifting and letting the rpm's rev up. Seems like the same thing, or not?
    SEXICAN
    2013 Q5 3.0T-DD
    2002 Honda Civic
    Orange County, CA
    good peice of advice right there... same thing applies to trying to drive spirited when your not good at shifting yet, if you hit 2nd instead of 4th your effed.
    B5 Parts For Sale
    May 20 2004
    More cars
    Never Land Ranch
    ok ok, that makes sense ^^^^
    SEXICAN
    2013 Q5 3.0T-DD
    2002 Honda Civic
    Feb 29 2004
    99 Audi A4
    Long Island, NY // the ATL
    NOT THE SAME THING!!! When you are stepping on the gas and let the engine rev too high the way the rev limiter works is that it cuts off the fuel to the engine. But when you downshift and the car revs too high its because the momentum of the car is causing the engine to turn that fast and therefore there is nothing that cutting off the fuel can do. Therefore...bye bye engine.
    Also, just to clear something up... letting it hit the rev limiter isn't "good." it causes a very lean condition in the engine due to the cut off of the fuel. obviously hitting it once isn't the end of the world though.
    Orange County, CA
    yea, thats what i mean, you can bounce off it once to see where it is and it wont do anything, but obviously dont make a habit, youve got a shifter for a reason.
    B5 Parts For Sale
    Mar 02 2004
    Orange County
    for instance you see a guy hit you up on the highway and you drop down to 4th gear to hammer on it, if you miss and get into second you are shit out of luck.
    Mar 02 2004
    Orange County
    or if you wanna get technical thats fine too.
