Results 1 to 15 of 15
    May 02 2004
    99.5 1.8tqm
    Flemington, NJ
    Car not pulling like it first did with the chip
    First my car was surging a little bit between 2-3 rpm. I have a 1.8tqm w/Giac chip btw. Then I picked up a 710n and it solved the major surging. It still surges in the 4-5 range. The car also doesnt feel like its pulling like when it did when I first chipped. Not as much torque. Your question is probably was is my boost guage reading, well Im getting one right before waterfest. But im looking for something to solve this.
    4 wheels
    2 headlights
    1 glovebox
    1 ac unit
    1 radio
    1 engine
    CO
    Not having much to go on here I'd ask the question, is it possible that you've just gotten used to the chip? I mean, I'll be the first to tell you my car doesn't "feel" the same as it did when I first got the chip. It still pulls hard and the boost has remained consistant, but if the seat of my pants answered that you'd get a different response.
    However, it is entirely possible you have some sort of a problem. You say you experience some surging. I don't have a GIAC, so me not experiencing this doesn't say much. I think the best place to start is with the boost gauge. Then, look for some leaks.
    Registered Member Three Rings
    May 28 2004
    00' VW MKIV GTI GLX
    PNW - 509 reppin' hard
    Whats the weather like down there? Humidity and heat kill the 1.8t's performance.
    MKIV GTI GLX
    Veteran Member Four Rings audidood's Avatar
    56 Oval, 2017 Tacoma
    san diego, ca
    boost leak?
    2004.5 USP A4 1.8t with mild mods.
    1956 VW Bug with major mods.
    Registered Member Four Rings Zodiak's Avatar
    Washington DC
    Originally posted by audidood
    boost leak?
    agreed
    Apr 29 2004
    Originally posted by Zodiak
    agreed
    Third that, check your lines and the bpv.
    Registered Member Four Rings joeya103's Avatar
    Apr 04 2004
    98.5 A4 1.8T Tip FWD
    Northern VA
    Yea, it'll be clearer when you get a boost gauge.
    =D
    I can say that because I finally have one....thanks Zodiac for all your help dude!
    May 02 2004
    99.5 1.8tqm
    Flemington, NJ
    im going to have mine in at or just before waterfest. i would think its a leak too because i changed the bpv.
    4 wheels
    2 headlights
    1 glovebox
    1 ac unit
    1 radio
    1 engine
    2009 A3 2.0T Quattro S-Line
    Vancouver, BC Canada
    i would expect boost leak as well...
    wonder wat's the peak psi is for stock program?
    peak psi for NDBW APR chip?
    and for Giac??
    i am currently running stock program for now, will get bak my APR ecu soon. wat do u guys experienced for AEB engine with APR chip??
    IG:@steadysupreme
    Pics&Detail
    May 02 2004
    99.5 1.8tqm
    Flemington, NJ
    which lines should i check for a leak. i know its the vac lines, but where are they located, and where would a common leak spot be
    4 wheels
    2 headlights
    1 glovebox
    1 ac unit
    1 radio
    1 engine
    Veteran Member Four Rings littlewhite's Avatar
    PNW Rainy States
    and for Giac??
    will get bak my APR ECU SOON. . . i've been hearing that for like past 6 months.
    Littlewhite
    Jul 09 2004
    California
    MAF
    Sounds like what happened to my car. Turns out it was a dead MAF sensor.
    May 02 2004
    99.5 1.8tqm
    Flemington, NJ
    how do i replace it and where can i get it. is there any way to check it?
    4 wheels
    2 headlights
    1 glovebox
    1 ac unit
    1 radio
    1 engine
    Registered Member Three Rings BoostinA4's Avatar
    Jul 12 2004
    i would check the hose that goes from the bpv to the throttle body, when i got my car chipped it didnt do anything cause that hose has a leak in and and i replaced it and it doubled my boost, hoses on the 1.8ts mine as well be made out of wet paper....they rip and leak so easily start up ur motor and listen for leaks or spray some soapy water and check for leaks
    http://www.audizine.com/gallery/data...765sig-med.jpg
    http://www.cardomain.com/memberpage/589435/4
    -----FOR SALE HERE!!!-------
    ATP manifold
    T28 wastegate
    440cc greentops
    RS4 bumper
    (2) Sparco 3pt harnesses
    HKS ssq BOV w/adapter
    (2) 4 bar FPRs
    Feb 13 2004
    <> Posts: 9913
    I'm not aware of any hose that goes from the BPV to the TB. I think you mean the one that goes to the intake manifold.
    -Theodore Roosevelt, 1907
