Results 1 to 13 of 13
Thread: Esp?
    Registered Member Two Rings
    Feb 24 2004
    00 S4, 00 Jeep Grand Cherokee
    Victoria, MN
    Esp?
    What exactly is ESP... I don't have it on my 2000 as it was not yet available.... just curious? Thanks in advance
    Registered Member Two Rings S4midable's Avatar
    01 S4 GIAC Stage II+
    Chicago, IL
    traction control- if it detects wheel slip then it automatically cuts the power by 25% to that wheel.
    Veteran Member Four Rings illusive45's Avatar
    Feb 13 2004
    2009 Audi R8 - Gated Manual V10 | Former: 2006 A6 Avant 3.2:: Techno|Premium|Cold Weather
    SF Bay
    Electronic Stability Program. Bascailly Audi's traction control system. Its not a must-have option. Your Quattro system is plenty stable for most conditions, plus if you're a road racer, I've heard you're better off without it.
    2009 Audi R8 V10 Gated Manual Sepang Blue, Tuscan Brown interior, Carbon Sigma Sideblades, Carbon interior, Stasis tune, Stasis exhaust, JRZ RS Pro 3 coilovers, HRE P40SC 20" wheels
    Former:2006 Audi A6 Avant 3.2:: Atlas Grey|Black leather
    2000 Santorin Blue S4 6MT , 1999 Volcano Black A4 1.8TQM, 1992 Sentra SE-R
    Track Weapon:: 2004 BMW M3 6MT
    Apr 03 2004
    Pasadena/Berkeley
    ESP can be a good thing to have if you drive in bad weather all the time but its not a neccesity...If you track your car, the ESP is your enemy because it kinda limits your car.
    Feb 24 2004
    Victoria, MN
    Oh well, sounds like I am not missing anything special... thanks all
    2000 Tip Silver S4, MTM chip, M3 Lip-Spoiler
    Veteran Member Four Rings buck's Avatar
    Feb 16 2004
    '05 Tacoma & '03 Yamaha R6 & '14 Yamaha FZ-09
    Simcoe County ON, Canada
    correct me if I'm wrong, but isn't ESP only an option for 2WD's?
    APR 93 Octane Chip, VDO Boost Gauge, 710N, Koni C/O's, Carbonio CAI, High Flow Coconut air freshener.
    60% of the time, it works EVERY time.
    Established Member Two Rings indica's Avatar
    2001.5 Audi S4
    detroit / whitmore lake
    well I have always thought that the s4's have always had the traction control(ESP), but in the newer 01-02 there was now just a button that enabled us turn it off. I have the ESP button and that is the first thing i do after starting the car.
    2001.5 S4|6-spd|brilliant black on onyx|apr stage two|vogtland c/o|oettinger pedals|neuspeed rear sway|volks|034 mounts|JHM ss & linkage|apikol diff mount|
    Veteran Member Four Rings Imperial's Avatar
    Köln / Cologne - NRW
    Nope, ESP is for both front-wheel and all-wheel drivetrains.
    PLVS VLTRA
    Veteran Member Four Rings cj-S4's Avatar
    Not enough space here
    Somewheretown, PA
    Also ESP is not just traction control. It is also a yaw control system. Too bad you can't turn off the traction control, but leave the yaw control on.
    Feb 16 2004
    you learn something new everyday!
    Senior Member Three Rings EuroTall's Avatar
    Feb 15 2004
    Tampa, FL
    Please enlighten the unfortunate who never heard of Yaw control.
    I thought ESP was what was mentioned above ...the 25% power decrease to the slipping wheel, but yaw?
    TIA
    2001.5 - Casa White S4 [2+]
    2002 - Tundra
    SOLD: . . . 2001 Audi A4
    SOLD: . . . 1963 Dodge Dart - slant 6
    DONATED: 1985 Dodge Ramcharger SUV
    Veteran Member Four Rings aussie_s4's Avatar
    2001.5 S4
    Originally posted by EuroTall
    Please enlighten the unfortunate who never heard of Yaw control. I thought ESP was what was mentioned above ...the 25% power decrease to the slipping wheel, but yaw?
    TIA
    When your car comes to a corner, physics wants it to keep heading in a straight line, unless there are forces to change its direction---like a driver pulling on the steering wheel. When you turn your car through a corner, it will usually go where you point it, but if you push it hard, you can experience oversteer, understeer or tire slip.
    Yaw control helps the car follow the intended cornering line by dynamically adjusting the torque between the right and left wheels. For a right turn, apply more torque to the left (outer) side of the car, less torque to the right (inner) side. It's like when you're rowing a boat, you put more effort into the left oar to turn right. Or if you're standing on a bus or a train and it makes a turn and you have nothing to hold onto, you balance your weight to the "outside" leg to keep yourself steady.
    With the yaw control enabled, the car feels like it's on rails, with less steering effort, less tire squeel and improved stability.
    I hope that explains it without getting into complicated tech details (because that's about all I know )
    2001.5 S4 - Denver, CO
    - Valeo E-Codes - 710N DV's - Neuspeed 19mm rear sway - StopTech 332mm Front BBK
    - 19x8.5" B7 RS4's - Falken Azenis ST115 235/35/19 - Nokian Hakka RSI 225/45/17
    - RS4 Grille - AutoVation race pedals - XM Satellite Radio - GPS
    Go hard, brake late.
    Registered Member Four Rings dramaticstatic's Avatar
    May 13 2004
    2000 S4
    Delaware
    You've pretty much got it exaclty with that one.
    The way I see it is ESP is basically a safety thing.
    It prevents you from really overcooking it into a corner and screwing up real badly.
    I leave it on because I've found that it (espcially yaw control) really controls understeer of the car and say if I'm coming around a corner quickly and there's a deer right in front of me, esp will make sure I don't understeer like crazy and plow right into it.
    It does limit the car but I like the extra safety it provides.
    I've also heard the Porsche on is worse and if you actually leave it on all the time it will limit how fast you can accelerate and brake because it assumes you don't know how to drive the car well.
