Results 1 to 9 of 9
    Veteran Member Four Rings Mark's Avatar
    1959 MGA 1600
    Chocolate Land, USA
    Pinging while going uphill at low RPM.
    I have been noticing that I am getting a slight pinging or knocking at low rpm's and while going uphill only. It is easily replicable and all you need to do is go up a hill in third gear at around 25mph. It is a rattling noise that sounds like a ball in a coffee can. It is not the DV, as I replaced that to try and fix the problem. The boost gauge says I am at around negative 7-10inHg, so no boost at all. If I get on the gas a bit more and accelerate with positive pressure then it goes away.
    How many others have noticed this??
    -Mark
    1987 5000 CS TQ 2.2T I5 - No more . . .
    2002 Denim Blue A4 1.8TQMS - RIP
    2005 Ebony Black Pearl allroad 2.7TQMT6
    Kinda stock . . . Tinted, H-Sport Sways, HP-2 Calipers, RNS-E, Bluetooth, and iPod/Sirius combined
    Got Vag-Com?
    Veteran Member Four Rings fongaroos's Avatar
    Feb 12 2004
    cali
    im really not sure what pinging is...
    and i dont know exactly waht it sounds like...
    BUT
    i do know that before AND after i was chipped...
    occaisionally the engine would sound very rough. like it wasnt oiled or somethign...
    i think it also tends to happen more when its hot. or the engine has been running a long time already.
    there is a completely different sound though when i first start up the engine. it idles pretty rough and then a few minutes later it goes away.
    Veteran Member Four Rings teutonic_blur's Avatar
    Puerto Rico
    Re: Pinging while going uphill at low RPM.
    Hmmm. The obvious explanation would be too much timing advance but that wouldn't explain why it goes away when you get on the gas.
    Maybe when the pressure goes positive the timing is retarded and that stops the pinging?
    I have never, ever, experienced pinging with Revo.
    If A is a success in life, then A equals x plus y plus z. Work is x; y is play; and z is keeping your mouth shut.
    Albert Einstein
    It's not that I'm afraid to die, I just don't want to be there when it happens.
    Woody Allen
    2003 A4 1.8T FWD 5M
    Revo SPS1, K&N drop-in, NGK Coppers
    Veteran Member Four Rings zemun2's Avatar
    Feb 20 2004
    '04 A4 1.8t FWD APR Tuned
    Zemun, Serbia.
    Mark,
    You've just described the problem I'm having with my Sk04 kit.
    I think it's advanced timing.
    Dejan
    APR Tuned Serbia
    Authorized APR Distributor
    1959 MGA 1600
    Chocolate Land, USA
    Re: Re: Pinging while going uphill at low RPM.
    Originally posted by zemun2
    Mark,
    Dejan
    You probably are correct. I wanted to see what others were experiencing with their setups and see if they had the same symptoms. it sounds like a Neuspeed K04 software issue.
    I emailed Anthony at Greedspeed and he asked about my fuel octane and plugs. I always run 93 octane and just changed my plugs 500 miles ago using NGK BKR7E copper plugs. I will see if I can get the timing of my program backed down a little bit.
    -Mark
    Got Vag-Com?
    1959 MGA 1600
    Chocolate Land, USA
    hey zemun2, what plugs are you using. specifically, what temperature rating?? 6 or 7's? I am running BKR7E's and I wonder if they are too cold at low rpm's.
    -Mark
    Got Vag-Com?
    Veteran Member Four Rings neoprufrok's Avatar
    NOR CAL
    Hope you figure that out mark. I'm fairly interested in a K04 and was hopin that the K04 software would be free of glitches...
    Currently:
    2018 GT3 Touring - Graphite Blue Metallic
    2016 McLaren 675LT - Mexico Blue with Roof Scoop
    2019 BMW M4 Convertible - Yas Marina Blue Competition Package
    Will be missed: 2001.5 Audi S4, 2004 Audi A4, 2004 Audi A8, 2008 Audi RS4, 2016 Porsche Cayman GT4, 2018 Porsche GT3.2, Mercedes C63 Black Series, McLaren 12C Spyder
    Podcast and Instagram: The Throttle Dogs
    1959 MGA 1600
    Chocolate Land, USA
    I just noticed it recently . . . I'll keep you guys informed.
    -Mark
    Got Vag-Com?
    Feb 20 2004
    Zemun, Serbia.
    My SK04 came with IK24's and the car was pinging like crazy, replaced them with BKR7E's and pinging went down a little bit.
    IMO 6E's are too hot for the SK04/K04 setup, try them for a week or two and see how you like it.
    APR Tuned Serbia
