Results 1 to 15 of 15
    Registered Member Two Rings theblackaudi's Avatar
    Jun 28 2004
    Automatic shiftknob
    Is there any way I can put a manual shiftknob onto my 1996 automatic shifter? I tried putting it in 3rd gear and trying to take it off like in the tiptronic shiftknob guide, but it won't come off the same way, although the button will pull out partially. Thanks.
    GTA, Canada
    You pull the button out, then start pulling on the knob. It takes a lot of force to get it off, just be careful, it can pop and then you'll smoke yourself in your face.
    RippleChip (Ryan) - Moderator
    Audizine
    01.5 eh4 1.8T || 12 eh5 2.0T
    Jun 28 2004
    Will I need that aluminum tiptronic adapter? I can't seem to pop the button out, and even when I pull the button outwards, and then pull up on the shiftknob as hard as I can, it won't come out. Any tricks to this
    GTA, Canada
    The button doesn't actually come out.
    Pull on it as far as you can get it out, then start working the shift knob up. You might need to get something to help it pop off.
    Have you read the instructions on how to change the shiftknob?
    Audizine
    Jun 28 2004
    Yes, I wasn't sure if it was the same as the tiptronic shiftknob, though. I'll go take another shot at it again. Thanks man.
    GTA, Canada
    I had to use a covered screwdriver to help pop it off. Just be careful not to damage it
    Audizine
    Jun 28 2004
    Anyone have a place I could upload pics? the leather part of the shiftknob came off, but now I'm kinda stuck as to what to do, considering nothing else seems to want to come off. I just took some digital pics.
    Registered Member Four Rings Zodiak's Avatar
    Washington DC
    http://www.audizine.com/gallery/uploadphoto.php?cat=500
    Jun 28 2004
    Well, here are the pics:
    http://www.audizine.com/gallery/show...00&ppuser=2626
    If anyone has any suggestions, I'd really appreciate it, driving around with this will look like crap without a real shiftknob :-p
    Feb 10 2004
    2009 A4 2.0T Sedan
    Wow, you busted that stock knob up something aweful. Did you push the plastic chrome sleeve down before you started pulling up on the tip knob?
    After you pull the button out as far as it will go, you'll just need to pull up on the rest of the tip knob and it should come up. As Ripple said, it takes quite a bit of muscle, and be careful not to pop yourself in the face.
    I changed mine out awhile back with one of these...
    Jun 18 2004
    Audi A4 1.8T Quattro
    nj
    i have a 97
    im as far as u are
    keep us updated
    plus..where can i go to get a shift knob for a 96-97
    i dont think that rs6/epi one will work on our cars
    Jun 28 2004
    so you're trying the same thing with your auto? If so, keep me updated on your progress too.
    Jun 18 2004
    nj
    i tried it a month ago
    i got a far as u did
    and glued the leather peices back together
    we're ****ed..just forget it
    Feb 12 2004
    99.5 1.8T A4
    Cleveland OH
    Haha, still trying to get it off????
    Veteran Member Four Rings DRA4's Avatar
    Feb 12 2004
    B5 S4
    The RS6 knob looks nice but only comes in black.
    Giac stage 1 279whp-327wtq
    TEAM A.C.E. NY
    Me: Siri where do lesbians hang out?
    Siri : I found 2 Subaru dealers fairly close to you
