Results 1 to 13 of 13
    Feb 15 2004
    2009 M.B. C300 Sport 6Sp
    T.O. Canada
    Problem....My car is SLOW....
    I'm starting to think that there is a problem with my car...
    It's really slow, picking up at the lights, or basically anywhere...
    I'm peaking at 14-15PSI when I FLOOR the pedal, most of the time its around 5PSI...
    I can hear the boost, and the exhaust...etc......but the power jsut doesnt seem to be there...
    Anyone have any ideas??
    Any tests I could do?
    Feb 13 2004
    <> Posts: 9913
    It could be just the hot weather. Turbo cars are slugs when sucking in the hot air.
    If your boost/vac readings are normal, and you have no other symptoms of problems (i.e., bad plugs, etc...), the I'd say it's nothing out of the ordinary.
    What are your mods? You may want to list your year/model/mods in your sig. It just makes it easier for these issues.
    -Theodore Roosevelt, 1907
    May 20 2004
    More cars
    Never Land Ranch
    you ahve a leak
    SEXICAN
    2013 Q5 3.0T-DD
    2002 Honda Civic
    AMD/EPL Tial 605 B5 S4 SOLD
    Registered Member Two Rings I95Racer's Avatar
    Mar 05 2004
    [IMG]http://img34.photobucket.com/albums/v102/Srussttt/Audizine/A4driver.gif[/IMG]
    New York City
    Make sure you drive with the A/C compressor off.
    1999.5 Black A4 1.8T Quattro 5-Speed
    Feb 13 2004
    <> Posts: 9913
    Originally posted by Audi_A4_Quattro
    you ahve a leak
    If he's boosting that much, then I doubt he has a leak. He'd get funky readings.
    We'd need more info in order to diagnose this.
    Feb 15 2004
    T.O. Canada
    1999 1.8TQ
    Upsolute Chip
    cone intake
    hi-flo cat
    miltek exhaust w\ DP
    Active Member Four Rings
    Are you goiing into limp?
    Veteran Member Four Rings skene's Avatar
    Feb 13 2004
    Las Vegas
    maybe stock?
    2017 Toyota 86
    Mar 01 2004
    PA
    Have you checked your vacuum lines? Any surging?
    2001.5 1.8TQM / GIAC / Koni Sports / Neuspeed Race / Borla V2 / V&S short shifter / Greddy III TT / Ipod-IceLink
    AIM: ornjblud34 / ornjblud at work
    Feb 15 2004
    T.O. Canada
    I've replaced my vacuum lines a couple months ago.....so that shouldn't be the problem...
    What is limp mode?
    I got VAG, but no codes come up
    Veteran Member Four Rings DRA4's Avatar
    Feb 12 2004
    B5 S4
    Is your Cell light coming up?
    Giac stage 1 279whp-327wtq
    TEAM A.C.E. NY
    Me: Siri where do lesbians hang out?
    Siri : I found 2 Subaru dealers fairly close to you
    Registered Member Four Rings Zodiak's Avatar
    Washington DC
    I assume your vac reading is very close to 20inHG at idle, and you're boosting fine, maybe it's just the warm weather (like previously stated. Sounds like your car is running fine, you're probably just used to the power now.
    Feb 15 2004
    T.O. Canada
    No CEL..
    Yes, my VAC is around 21inHG when idle....
    But I'm pretty sure its gotten slower....off the line, I'm not keeping up to other cars during regular driving (ie. camrys, mini-vans..etc..).....
