Results 1 to 28 of 28
    Feb 13 2004
    <> Posts: 9913
    Another BPV / DV Alternative
    After being chipped, many need to upgrade their stock Bosch 710 Bypass Valve. Most (including me), upgrade to the TT Coupe 710N, which is an improved version of the stock 710 valve, found in the A4. While this valve has been more than reliable for me running about 15psi of boost, but some people here are running higher levels of boost and want an even more reliable, longer-lasting valve.
    Which brings me to the Bosch 110 valve found in the Porsche 996, which is another great alternative, and I never hear anyone mention it. It's said to be a stronger valve. It's also very affordable relative to the other aftermarket diverter valves, like Forge, Bailey, etc...
    Anyway, you can get this valve from most dealers for about $45.
    Is anyone else running this valve?
    -Theodore Roosevelt, 1907
    Mar 27 2004
    2001 A4 1.8T
    PA
    Are you talking about this one?
    http://www.hoppenmotorsport.com/bypass.htm
    2001 A4 1.8TQMS - SOLD
    Mods: APR 93 octane, Milltek Catback, 710N, V&S SS, RS4 grill, RS4 reps, Sport Seats, AWE DTS, Neuspeed 19mm w/ metal end links, S4 wheel liners, PureMS Strut Bar
    Convenience: "one touch up" rear window mod, PhatBox
    my Member Gallery
    Veteran Member Four Rings alen's Avatar
    May 10 2004
    1.8tqms
    ghettlanta
    i've never heard of this valve until today when a friend of mine gave me his two DVs. one is the 710N and one is the 110 porsche DV. he used them both for a very short amount of time on his gti 1.8t and he liked them both until he switched to forge. he told me that the 110 was also used on the older S4 (92-94) so is that true?
    i'm installing one of the DVs on my car tonight so if i have enough time i will prolly test them both out and report back here (it's my first time doing this).
    it's funny how you wrote this today and i got those valves today, too.
    Feb 13 2004
    <> Posts: 9913
    Yes, that's the valve. But it's a overpriced there. You can get it from the dealer for cheaper, and I even read someone got one from the partsbin site for about $23.
    I have read that many say the 110 is on par with the 710N, but many also claim it's a tougher valve, and much harder to tear. For a few extra bucks, I think it may be worth a shot. I've never been a fan of spending $100-$200 on a fancy valve that has to be serviced. I'd rather put a brand new part in every year or so, since it will still be cheaper than buying a pricey one.
    My DV's have lasted over a year easily, and should be good up to 30k miles, if not longer.
    Registered Member Two Rings
    Feb 16 2004
    99` a4qtip
    Nu York
    Sweet DDQ u the man thas what i was loookin for u 2 come up with and tell me bout it. =) ima order me one of those
    -=SiNeD=-
    http://img22.photobucket.com/albums/...AZsig_copy.jpg
    | Will work for mods !! | (Q'.')--Q(^.')> |
    Feb 13 2004
    <> Posts: 9913
    Thanks SSiNeDD, your post here is what made me look into it more: http://www.audizine.com/forum/showth...threadid=13955
    The symptoms you said you had are what I was saying is a sign of a faulty rubber diaphram in a BPV, which is also described here on Joe Hoppen's site: http://www.hoppenmotorsport.com/bypass.htm
    "As stated in Audi’s technical bulletin dated Dec. 8, 2000 the bypass valves should be replaced should the following occur: “Groaning or howling noise from engine compartment when accelerating during partial load between 2500-3000 RPM,” or “ Rattling noise when decelerating between 2000-3000 RPM,” which “may be caused by the internal diaphragm of the charge pressure bypass valve producing pulsating noises.”
    Feb 16 2004
    99` a4qtip
    Nu York
    sounds like the same prob i have
    sweet, i prob did blow the diaphram =\
    ill try n get the porch dv ASAP
    and let u kno on the outcome
    -=SiNeD=-
    Veteran Member Four Rings sumpsfast's Avatar
    Apr 02 2004
    '92 UrS4 - Black
    Denver/Chi-town
    Great post DDQ. You are fun to bicker with but you sure know your s--t!
    Veteran Member Four Rings needforspd's Avatar
    Mar 05 2004
    Deceased 01.5 A4 1.8tm
    Sylmar Hills
    I need a new DV. 710N or try this 110? Im not chipped .. yet.
    Do you have a need for speed? Then drive it like you stole it!
    Veteran Member Three Rings SoleMate's Avatar
    Jun 21 2004
    98 A4 & 94 E320 coupe
    Denton, TX
    Thanks for the info, I'm looking into buying one as we speak.
    APR chip
    FK coilovers
    HKS exhaust
    DPE R16 18x8/9
    rs4 grill
    Feb 13 2004
    <> Posts: 9913
    lol, it's never personal . I'm a sucker for debates, I can't resist, even when I have to play the devil's advocate.
    needforspd - If you're not chipped, the stock valve shoud be fine. In fact, my stock valve was old and still lasted for awhile after I was chipped. But, if you're going to replace the stock valve, you might as well just pick up a 710N for about $30 from ECS.
    Apr 02 2004
    '92 UrS4 - Black
    Denver/Chi-town
    You just want intimidation with the fist in the avatar huh??! I ain't scared
    Veteran Member Four Rings skene's Avatar
    Feb 13 2004
    Las Vegas
    710N found on the TTs is a semi decent replacement however it's still a Bosch valve with a rubber diaphram. 110 is a Porsche Turbo valve.. same bosch valve different application.
    Moral of the story.
    Rubber diaphrams still suck.
    Get yourself a piston based diaphram. ie. EvoMS BPV.
    2017 Toyota 86
    May 10 2004
    1.8tqms
    ghettlanta
    should i install the 110 the same way as the 710N?
    Feb 13 2004
    Las Vegas
    actually.. yes if you are going to replace it with a rubber valve.
    but Audi installs the valves backwards from the factory so that they are less prone to damage.
    2017 Toyota 86
    May 10 2004
    1.8tqms
    ghettlanta
    hmm, i don't understand now. this is my first time installing DVs and now i'm confused. i have a 710N and a 110 (porshe) and i want to test both of those out.
    the DV already on the car is a regular 710 but i can see that it was changed before b/c of the clamps. now, i don't know which way to install the 710N or the 110.
    Feb 13 2004
    Las Vegas
    replace it the same way only if its a 110 or 710n.
    2017 Toyota 86
    Feb 13 2004
    <> Posts: 9913
    Moral of the story.
    Rubber or not, it does it's job. And if I rip it, then I put a brand new part in my car for about $30. With other valves, you have lube them, clean then, adjust them, etc...
    With BPVs you'll never feel a difference in performance, they all perform, they all do the same exact thing. I don't need a fancy shiney valve somewhere I'll never see it.
    So, I guess it comes down to this: Do you want to install a brand new part in your car for $30 each service interval... or do you want to spend ~$150 for a part you have to remove, clean, adjust, and re-install each time?
    I'm not doubting that a piston design is more durable and longer lasting. But I just don't think it's worth the money.
    Active Member Four Rings
    I'll stick with my Bailey
    Mar 05 2004
    Sylmar Hills
    I dont have a stock one on. There's a TurboXS on there now (bought the car used) and it's leaking now so I need to replace it. Would rather replace then figure out how to fix the damn thing.
    Ill get the 710N then.
    Feb 13 2004
    Las Vegas
    yes.. look at it any way you want.. however I have never cleaned my bpv out... and it still works.
    I have however replaced 710n valves and such... think about it...
    If you consider that time is money.
    Then you spend $30.00 on a Bosch valve.
    time spent waiting for delivery which costs money or driving to the local dealership to purchase the valve which wastes gas (and we all know how the prices of gas has been per gallon).
    time spent jacking up your car and removing the old valve and reinstalling the valve.
    etc etc etc.
    How does your $30.00 valve look like now?
    2017 Toyota 86
    Feb 13 2004
    Las Vegas
    The TurboXS valve does not leak.. it may just need a cleaning cause the piston may have stuck or one of your hoses has a leak in it. but if it is a TXS valve... there is no way it can leak otherwise as it is a metal piston based valve.
    2017 Toyota 86
    Veteran Member Four Rings MKGIY's Avatar
    2012 S4, 2012 GMC Acadia
    New Jersey
    I have the TurboXS valve and ran some crazy psi (27) and not one leak and I have never taken mine out to service it. Best 150 i ever spent over 2 years ago.
    Mike
    May 10 2004
    1.8tqms
    ghettlanta
    ok, so back to my question now: when installing the 710N and the 110, the spring loaded end should connect to the IC piping, right?
    Mar 05 2004
    Sylmar Hills
    Hmmm ok, how do i clean the b!tch? What products to use, etc.
    Thanks.
    Feb 13 2004
    Las Vegas
    take it out... oil the piston.. clean off the oil... put it all back together.
    2017 Toyota 86
    Apr 02 2004
    '92 UrS4 - Black
    Denver/Chi-town
    I ordered the bosch 110 today from lindseyracing.com. $40 shipped (two day arrival). I have all the symptoms, sporatic boosts and less pull. Plus rattling AND the moaning at about 3k rpm. Hopefully it will make a diff.
    BTW, I do have the evoms CAI, but my blow off or return is rediculously loud right now. sounds reallly cool.
    CUUUSSSSHHHHHHH
    May 10 2004
    1.8tqms
    ghettlanta
    ok. i was going to write up my problem, but i'll just post it here. i installed the 110 the other day and so far i have some problems with it. i installed it the OPPOSITE of the pic below:
    it's slightly used (~1000 miles) so i guess it should be ok. but, i sometimes feel slight surging throughout the entire range and rattling at WOT in 3rd and 4th above 3000RPM. is this due to this BPV?
    also, after replacing it for the stock 710A, i hear less turbo whine and SSSSHHHHH (almost none) compared to the 710A. i'm running an EMCS2 APR chip.
    other than that, i don't have anything else to say about it.
