Results 1 to 4 of 4
    Apr 12 2004
    2000 stgIII s4, 1997 jeep
    denver
    annoying service indicator
    is there anyway to get rid of the service reminder that comes up between oil changes everytime you turn the car on, without going to the stealership??
    i read on AW there is a sequence with the KOEO, and the trip odometer that when done correctly will delete the reminder.
    Veteran Member Three Rings quicksilver_S's Avatar
    City that never sleeps
    Veteran Member Four Rings cj-S4's Avatar
    Not enough space here
    Somewheretown, PA
    The procedure is also in your manual.
    Apr 12 2004
    denver
    found it in the manual.
    2000 S4
    key off: hold odometer reset button, then while still holding this button turn the ignition on (1st click) then hold time/date button (closest to the tach) until the new service interval is displayed.
