Results 1 to 31 of 31
    Registered Member Two Rings koolAsiCE's Avatar
    Feb 26 2004
    Alfa Romeo 147, Audi A4 1.9TDi Quattro
    England, London
    Question Car does not move in gear
    Any one come across this?
    the engine starts, clutch down, goes into gear, hand brake off,
    but car does not move forward or backward.
    no transmission fluid leaks, level ok.
    any decent thoughts any one.
    Audi A4 manual 1.9 TDi quattro 1998 uk
    Account Terminated Four Rings MR VTEC's Avatar
    98.5 Audi 1.8TQM
    Brooklyn
    huh
    Registered Member Three Rings
    May 28 2004
    00' VW MKIV GTI GLX
    PNW - 509 reppin' hard
    Wow. Ummmmmm, are your driveshafts connected? ;-)
    MKIV GTI GLX
    Veteran Member Four Rings Starting's Avatar
    Feb 13 2004
    98 A4 1.8t
    Central, NJ
    when this happened to me my trans went. it could also be the front differentail or the front axels coming out.
    Feb 26 2004
    England, London
    diferentials look ok!
    Registered Member Four Rings Zodiak's Avatar
    Washington DC
    toasted clutch?
    98.5 Audi 1.8TQM
    Brooklyn
    does the car shut off
    did you try a different gear
    Veteran Member Four Rings Jon_Rhea's Avatar
    2001 S4 6 spd MT
    Manchester, TN
    yeah, try starting off in 2nd or something, maybe its just 1st gear thats messed up...???
    2001 Nogaro Blue S4
    Feb 26 2004
    England, London
    maybe but gears are selected ok; it could be a cracked flywheel, or clutch and flywheel stuck together, it hasn't been driven for a few months. but hoping to check all that out as last resort.
    Feb 26 2004
    England, London
    Question
    car shuts off, does not move in any gear.
    2001 S4 6 spd MT
    Manchester, TN
    I think he ment when you try to take off, does it die like if you pop the clutch or something.
    2001 Nogaro Blue S4
    Feb 26 2004
    England, London
    does not move at all,
    engine just revs!
    Veteran Member Four Rings D Piddy's Avatar
    Feb 12 2004
    Me: 2010 B8 A4 S-Line In the Family: BMW Z4M, BMW 335xi, Range Rover Evoque, Honda Element
    Washington, D.C.
    that's a disconnected drivetrain. could be disconnected/broken axles, bad CV joint, etc. that's the same thing that happened to me when i broek my axle while practicing...eh hem...er...spirited, circular winter driving
    Feb 26 2004
    England, London
    sounds like a possibility - thanks man.
    you wouldn't happen to know how much work's involved to fix.
    Feb 17 2004
    Sterling, VA
    Clutch problem, definately. Even if one axle was disconnected or broken the rest of the wheels would try to turn. Even if the rear driveshaft was removed, the front wheels would try to turn.
    The problem is that the clutch might actually be stuck in neutral position and that's why shifting feels fine. The question is how it's staying that way.
    Can you select a gear without pushing the clutch pedal? That would tell you what state the clutch is in.
    Other than that, the only way you could have gear selection and no movement is with a broken input shaft on the tranny. I'd wager that you get some horrible clunking though.
    Brett - Moderator
    Issue?: email me.
    _____________________
    Stage 3 2004 A6 2.7T 6M
    May 28 2004
    00' VW MKIV GTI GLX
    Damn. Great post turbo90.... :)
    MKIV GTI GLX
    2001 S4 6 spd MT
    Manchester, TN
    turbo90awd is da man!!
    2001 Nogaro Blue S4
    Feb 17 2004
    Sterling, VA
    Just tryin' to hook a brotha' up......
    Brett - Moderator
    Issue?: email me.
    Feb 13 2004
    98 A4 1.8t
    Central, NJ
    I would think transmission before clutch. If the clutch was grabbing fine before this. Same thing happened to me all of a sudden my transmission just went.
    Feb 26 2004
    England, London
    I'll give your idea a try before I eventually take it to the stealership or audi workshop - ( I'm trying to avoid them at all cost!!!!)
    Feb 26 2004
    England, London
    Any more ideas?
    Feb 17 2004
    Sterling, VA
    Give us an update on your findings.
    Brett - Moderator
    Issue?: email me.
    Veteran Member Four Rings buck's Avatar
    Feb 16 2004
    '05 Tacoma & '03 Yamaha R6 & '14 Yamaha FZ-09
    Simcoe County ON, Canada
    Sounds like a clutch.
    I had a spring let go in my pressure plate all of a sudden and the car would not move in any gear (obviously).
    If clutch/tranny repair is out of your mechanical abilities, get it towed to your trusty Audi service shop.
    If a CV or Axle broke - your car should still move, but with some funny sounds..... clickety click click
    APR 93 Octane Chip, VDO Boost Gauge, 710N, Koni C/O's, Carbonio CAI, High Flow Coconut air freshener.
    60% of the time, it works EVERY time.
    Active Member Four Rings
    It's the clutch. I had the same thing happen in an old eclipse AWD.
    Feb 12 2004
    Washington, D.C.
    i had terrible clunking. u could hear the axle rattling around in the front right of the car. but like i said, the car would not move. and i had no clutch problems. dunno y, when i gave it gas, the clunking would just get louder
    Registered Member One Ring All Outta Angst's Avatar
    Jul 11 2004
    1997 A4 TQ
    Melbourne, Vic, Australia
    One of my drive shafts (front left) fell off while I was driving.
    It resulted in not drive to the other wheels (1997 A4TQ), I expected power to still go to the other wheels, but no cigar.
    (it was the axle the speed sensor is connected to, so my speed went up :P)
    Feb 12 2004
    Washington, D.C.
    same thing. see i don't know y, but when the axle goes, no power gets to any wheel
    Feb 26 2004
    England, London
    Found out it was a cracked gear box all along and one of the gears has a collapsed rod selector.
    Got a second hand gear box and hey presto problem solved!!
    Thanks for all your comments!
    Feb 17 2004
    Sterling, VA
    Damn! How did that happen?
    Are your motor mounts in good shape? Perhaps the motor is moving around too much and it fatigued the tranny's case and cracked it?
    Brett - Moderator
    Issue?: email me.
    Veteran Member Four Rings e.van's Avatar
    Mar 09 2004
    1999 A4 Avant 1.8T quattro, 1976 BMW 2002
    Cleves, OH
    Similar thing happened to me, turned out to be the loctite bolt (don't know how it happened, but it came off) on the shift
    linkage.
    1999 Cactus Green A4 Avant 1.8TQM
    Black DEPO eCodes | 3000K & 4300K HIDs | City Lights
    Dual-Rear & Front Fog Mods | 1-Touch Windows
    LLTek Mesh Grille | 710 N | Dump-Truck Exhaust
    OEM B6 5-Spoke Wheels | Neuspeed Race Springs
    I think it's obvious that I don't care how fast my car is.
    Feb 26 2004
    England, London
    It got hit from behind; but still drove fine at first and no one was any the wiser.
