Results 1 to 19 of 19
    Registered Member Three Rings
    May 28 2004
    00' VW MKIV GTI GLX
    PNW - 509 reppin' hard
    My sunroof is alllllll effed up, please help....
    So last night I close my sunroof to wash my car...everything is fine. Don't notice anything while im washing or drying. And then I leave to go get some starbucks....i twist to the right to get it to just pop up, not slide back...and it makes 3 horribly loud clicking noises. I don't really think much of it.....and then I go to bucks' and get some coffee with some friends, I come back to my car and notice that only HALF of my sunroof opened. The other half is stuck shut. So i go out and and I switch it down and it closes, and then i turn it back up and push on the side that was stuck....to no avail. Soooooo now its really ****ed up. The drivers side rear(toward trunk) is down below the roofline as if it were in the position to slide back, and the passanger side front is kinda sticking up above the roofline, the passanger rear is kinda down as well. It won't slide back either, that really is a bad deal.
    So my question to you is, what the hell do I do. Is there anyway to get this thing back on its tracks? Am I going to have to take this to AoA or what? I really don't have tons of flow, so the cheaper the better fella's. Thanks in advance, and any help would be appreciated.
    MKIV GTI GLX
    May 28 2004
    00' VW MKIV GTI GLX
    15 looks and no help!? ;-)
    MKIV GTI GLX
    GTA, Canada
    Its hard to say. Sounds like the guide rails or something got messed up, seems like it could be jammed. Don't know how to attack this one.
    RippleChip (Ryan) - Moderator
    Audizine
    01.5 eh4 1.8T || 12 eh5 2.0T
    Veteran Member Four Rings Jon_Rhea's Avatar
    2001 S4 6 spd MT
    Manchester, TN
    yeah, it sounds like it came off the tracks, or something, but I don't have a clue what or how you would do to fix it....maybe try AW or search over there and see if anyone else has had a similar prob. before. Sorry I wasn't much help
    2001 Nogaro Blue S4
    May 28 2004
    00' VW MKIV GTI GLX
    It's all good guys! Thanks for the replies, at least I know that im fooked! Im sure AoA is going to charge me a ridiculous amount to get it goin ogain. Maybe I'll just go to to a reputable shop here....
    MKIV GTI GLX
    2001 S4 6 spd MT
    Manchester, TN
    yeah, I'd give them a call first though, who knows, it might be a quick simple fix. It be worth a phone call at least.
    2001 Nogaro Blue S4
    Registered Member Two Rings koolAsiCE's Avatar
    Feb 26 2004
    Alfa Romeo 147, Audi A4 1.9TDi Quattro
    England, London
    May 28 2004
    00' VW MKIV GTI GLX
    Score! Thanks Kool......even though it doesn't really tell me how to fix it, (the broken peice link). At least I know what probly happened. I'll take it to AoA and have them take a gander.....
    MKIV GTI GLX
    May 28 2004
    00' VW MKIV GTI GLX
    So i took it to AoA.
    $1200-1400 fix
    Said they'd have to replace the whole track.
    I have no idea what to do.
    MKIV GTI GLX
    Veteran Member Four Rings 4ingDrive's Avatar
    Feb 25 2004
    Chi town burbs
    Fix it yourself.
    99.5 A4 Avant
    always some shit broken
    May 28 2004
    00' VW MKIV GTI GLX
    I wrote a good smart ass comment for that response 4ingdrive. But I opted for this instead.
    MKIV GTI GLX
    Mar 27 2004
    2001 A4 1.8T
    PA
    Seriously, do it yourself. I know I wouldn't spend $1200 for something like that unless I absolutely had to. Find out how much the parts would cost by themselves at least and see if it makes sense to you. The hardest part would probably be getting the headliner out. I think I read somewhere that you have to take a lot of other bits out to get to that point.
    2001 A4 1.8TQMS - SOLD
    Mods: APR 93 octane, Milltek Catback, 710N, V&S SS, RS4 grill, RS4 reps, Sport Seats, AWE DTS, Neuspeed 19mm w/ metal end links, S4 wheel liners, PureMS Strut Bar
    Convenience: "one touch up" rear window mod, PhatBox
    my Member Gallery
    May 28 2004
    00' VW MKIV GTI GLX
    Oh man, I wish. If you knew me, than you would know that it is best if I don't try and fix anything. I always **** shit up. There is absoultely no way that I could try and do this myself. Not to mention the lack of tools and time on my part. I'm going to look around, and see if I can get anyone to beat AoA's 85$ ph shop rate :/
    MKIV GTI GLX
    Orange County, CA
    read some DIY guides to repair it before you rule it out, you could ssave yourself a hell of a lot of money that way, maybe youve just got something blocking the track and you can clean it out? who knows, whatever the reason is, make sure you do all you can before you pay someone to do it, thats some extra mod money right there if you get it done without having to fork over a grand.
    B5 Parts For Sale
    Feb 13 2004
    <> Posts: 9913
    Sunroof fixes are pretty involved. You have to remove A LOT to open it all up.
    Here's the ultimate write-up for the sunroof fix (pdf file, obviously): http://davidt7.home.comcast.net/docs/audi_sunroof.pdf
    -Theodore Roosevelt, 1907
    May 28 2004
    00' VW MKIV GTI GLX
    Yeah, it really is something that is going to be out of my grasp. Plus, I need it to be done in 1 day, so i don't have to miss work. And the sunroof is really tweaked out, it's much more involved than just unsticking something.
    MKIV GTI GLX
    May 28 2004
    00' VW MKIV GTI GLX
    Just went out and ****ed with it some more. Got it to slide all the way back.....but now it won't close. However, I think this is better than it was because it's not all tweaked out now. Now I think it is just a plastic jam. When I go to switch it closed, it makes a bunch of shitty popping noises, stalls, and then go's back. It's like the pin is going forward, gets binded, and then goes back as a safety measure. This is all without the sunroof actually moving forward. I can't get any movement out of it....anyone?>
    MKIV GTI GLX
    Feb 13 2004
    <> Posts: 9913
    Your guides sound like they're toast. Search on AW, and see the link I posed above. You'll likely need to replace the plastic rail guides. Not a simple fix, there's no secret to it.
    May 28 2004
    00' VW MKIV GTI GLX
    damnit. Thanks DDQ, appreciate the help.
    MKIV GTI GLX
