Originally posted by hotreel
I cant seem to make up my mind on which exhaust to go with. After searching the threads ive come up with very mixed reviews on both of them. My main concern is sound and performance. Is the thermal exhaust too loud? Does it sound at all ricey? And how does the milltek sound? Anybody have any sound clips of it? And is it worth the extra $$$. I definitely want one of the two and just need to decide. If anyone can give me some input it would be greatlt appreciated? Thanx in advance
I'm no exhaust guru. But I have had three of them on my A4 and have heard/seen others too.
First; those two exhausts are at opposite ends of the exhaust spectrum with regards to sound/noise, interior drone, pipe size/flow, performance, as well as design/build.
Second; sound and looks are VERY subjective.
Third; there are good experiences and bad experiences within the same brand of exhaust.
Fourth; what is "good sounding" and what is "too loud" to you?
That said, my choice is MTM of course, because I think it is the best of all worlds; performance, tolerable sound levels inside/out, build quality and looks. But that's mucho denaro. So if you want to keep your cost down, but get the best of both worlds (i.e; sound and performance), then the two you picked are not very comparable for that since they are quite different. The Thermal Race has bigger pipes and thus better flow most likely, but also much more noise/sound. It's pretty loud from what I have heard mentioned by owners. But again, sound is very subjective. Some want the noise level to be loud, while others prefer less (especially with regards to interior noise/drone). The Milltek has smaller pipes and isn't as loud sounding. Two very different exhaust systems.
There have been many documented fitment issues with Milltek exhausts on A4/S4 B5/B6. I recall one where the customer had numerous issues with fitment and even ended up sending it to Milltek in the UK, and yet it still had problems even after they returned it. And then some others say theirs fit perfectly. Same with APR. I had one and it was horrible in everyway. It fit poorly and even grinded against the driveshaft. I heard from someone else who had it as well and they also had similar issues. Yet some others with it said it was fine. I also had the GHL and that had fitment and quality control issues, as well as intolerable drone, so I returned that one as well. I didn't care for either of them and my view of aftermarket exhausts was looking grim. Then I decided on MTM's exhaust. Couldn't be happier. It offered everything I wanted in an exhaust; tolerable sound levels (especially inside), performance/flow (full 70mm [2.756"] pipes, OEM like fitment, heavy-duty build quality and polished rolled tips. Even w/o a DP, it still felt like the flow was as good, or better, then the full 2.5" GHL w/ DP. APR was a 2.5"/2.25" system and was noticeably reduced in power/torque when compared to the GHL. So consider that the Thermal Race is a mix of 3"/2.5" & 2.25" I think. And the Milltek is a mix of 50mm/60mm. That's not very big (Neuspeed is a full 60mm system). So as I said before, the Thermal and Milltek are at opposite ends with sound and performance, so it doesn't make it easy to choose/compare as they are very different exhaust systems.
I have heard from some Thermal Race owners that it is pretty loud. One person wanted to get something else because it was just too "drony".
One sure way to help you decide is to find somone local to you with either one and go check it out in person.
