Results 1 to 10 of 10
    Registered Member Two Rings
    Apr 17 2004
    Greenville, SC
    Question Best plastic joining glue for center cap?
    What should I go buy to put my center cap together?
    I removed the flik sticker and now I'm ready to glue on the audi cap and want to use something that is going to last...I still plan on smoothing down the audi cap to get a better surface.
    Veteran Member Four Rings FITZ TITS's Avatar
    Phila
    plastic welder.
    Apr 17 2004
    Greenville, SC
    hmm if a plastic welder is anything like true welding I'm afraid I would make too much of a mess. The outside joint will probably mostly be hidden but I don't want to make it look sloppy.
    Feb 13 2004
    <> Posts: 9913
    Maybe try a silicone glue? Everything I've used it on has lasted a long time.
    -Theodore Roosevelt, 1907
    Connecticut
    epoxy?
    01 a4 1.8tqm, giac x, borla, h&r sport
    7.66 CAPS
    Veteran Member Four Rings Burntaudi's Avatar
    Sold:1997 Audi A4
    Maplewood, Minnesota
    Use a 2 part epoxy and I would suggest roughing up the 2 surfaces that need to be bonded. They will adhere much better.
    Alex
    Sold 97 Audi A4 Turbo Quattro Manual
    KO4/GIAC PC-16/GHL Exhaust/EVO FMIC/ Southbend Clutch/JHM Short Shifter & Linkage/Shifter Bushing/Koni Coilovers/Neuspeed Sways/17" OZ Superellegras/Ecode Headlights/VVME Hids
    Current ride 03 Tahoe Z71
    Registered Member Three Rings widm3r's Avatar
    May 02 2004
    LI, NY
    Those center caps will make your Fliks look so much better and your Avant!
    Widm3r
    Apr 17 2004
    Greenville, SC
    Thanks all, I'll go out looking for stuff today!
    I hope so widm3r...I'm hoping the silver is close enought to the Fliks silver color.
    Veteran Member Four Rings A4 in SC's Avatar
    Feb 16 2004
    '84 911 Carrera GP White, Burgundy cloth
    Simpsonville, SC
    I agree. I'd use some 2 part epoxy. It works wonders with plastic. I acutally held off buying a filter for my pool (my previous house) for a year with that stuff! Of course, if it will hold up under that much water pressure, it'll certainly hold up on a set of center caps.
    Later,
    Mike
    Registered Member Four Rings jesseahhstyle's Avatar
    OC, California
    Get the stuff made for plastic/urathen materials. It is a 2 part epoxy. My mirror was knocked off and I Epoxied it back together with that stuff and it came in a white cream color. Matches good with my pearl, can hardly see it!
    Thats your best bet!
