Results 1 to 12 of 12
Thread: B5 S4 brakes...
    Veteran Member Four Rings fongaroos's Avatar
    Feb 12 2004
    cali
    B5 S4 brakes...
    im thinking about pickin up a set of calipers... but i dont know where to get rotors from...
    avanteix had suggested that i get em from ECS tuning.
    is that a good place to go for rotors?
    i have so many questions about braking systems cuz i really dont know much about them at all...
    1) regular? slotted? drilled? which ones do i get?
    2) brake pads? which ones...
    3) SS brake lines? are these really worth it?
    4) brake fluid? why motul? why cant i just get standard brake fluid?
    5) is the install hard?
    6) what about brake bias?
    7) do i need to change the rear braking system?
    i think thats about it...
    im sure ill come up with more...
    my car is a daily driver and i really dont push it that hard...
    in fact i think the only reason im getting these is because im getting wheels soon and i want something a little... bigger to fill in the back of the wheels. and also... the stock B6 A4 brakes are kinda... (for lack of a better word) mushy
    im not going autoxing so i dont need like TOP OF THE LINE anything. i just want something thatll perform better and look nice behind the wheels
    Registered Member Three Rings
    Apr 28 2004
    Staten Island, New York
    Well im doin same mod ...heres my take ...Im goin w/ Ecs slotted and cross drilled rotors that are made by Zimmerman (mainly for looks, its not like i need tremendous braking power) I figure on upgrading the lines and the fluid just to finish up the front brakes nicely . Im not sure about pads right now because most dont have sensors(dont really like that ) Not upgrading back brakes yet but in future may ...I believe a few people have just upgraded front brakes and done it themselves ....Alipor on Audilounge did a how to on the install
    Veteran Member Four Rings Mark's Avatar
    1959 MGA 1600
    Chocolate Land, USA
    I have changed my S4 rotors 4 times already. It can be hard to find a nice match. At first I had two sets of stock rotors that both vibrated. I then had a set of Disc Brake Australia long life slotted rotors and they vibrated horribly. I emailed them about the problem about a month ago a they replaced them with an updated pair for free about 2 weeks ago. They no longer vibrate and are fantastic.
    -Mark
    1987 5000 CS TQ 2.2T I5 - No more . . .
    2002 Denim Blue A4 1.8TQMS - RIP
    2005 Ebony Black Pearl allroad 2.7TQMT6
    Kinda stock . . . Tinted, H-Sport Sways, HP-2 Calipers, RNS-E, Bluetooth, and iPod/Sirius combined
    Got Vag-Com?
    Feb 18 2004
    Rosemead, Ca
    my stock s4 rotors will randomly vibrate, it'll do it for a few stops then go away. really strange
    Veteran Member Four Rings zemun2's Avatar
    Feb 20 2004
    '04 A4 1.8t FWD APR Tuned
    Zemun, Serbia.
    What kinda brake fluid did you upgrade to?
    APR Tuned Serbia
    Authorized APR Distributor
    Feb 12 2004
    cali
    anyone know anything about the ECS rotors matched with the B5 S4 brakes?
    any feedback on the combination?
    what kind of pads should i be using?
    do i need to get motul?
    do i need SS lines?
    Apr 28 2004
    havent done mod yet ....havent ordered fluid or lines or pads yet ....im know Im gettin them just dont know which pads or fluid .....in response to fongaroos .....no u dont need motul or SS lines
    Feb 23 2004
    2004 A4 1.8T Ultrasport 6MQ
    Stow, OH
    So far, I've replaced my OEM rotors with ECS OEM 2 piece floating slotted rotors. It's the same size as OEM so I can use the original caliper and save 23% in unsprung weight. The pads are now Hawk HPS which has more bite, but they've been prone to become loose inside the caliper (a lot of rattling).
    For brake fluid, I flushed out the OEM fluid and replaced it with Motul RBF600. Haven't touched the brake lines.
    With this setup, I've experienced stronger and shorter stopping power without unwanted brake fade.
    I chose this setup so I can still use my OEM 16" wheels for winter use and still have performance stopping power all year long. I'm getting many benefits from BBK designs, but at a fraction of the cost.
    Question: can the B5 S4 caliper fit onto the B6 A4 3.0 rotor? That would be a nice upgrade from a single piston to a two piston caliper setup.
    USP CLUB MEMBER #34
    Established Member Two Rings 1.8WAGA4's Avatar
    Feb 20 2004
    2002 A4 Avant 1.8T
    Mtl, Can
    do i need SS lines?
    Here is the set up i'm currently running with my B5 S4 calipers:
    rotors from ECS = Zimmerman slotted and cross drilled
    Neuspeed SS lines
    Mintex red pads (they have sensors)
    Prestone fluid (don't know very much about fluid; always used Prestone before without having trouble)
    The calipers have been completly rebuilted. The install was very easy; it's bolt-on so no major problem. I didn't do any changes to the rear brakes; still stock.
    I've seen major brake improvment, a lot more stronger, shorter braking distances. No vibrations at all.
    The bad point is that they are noisy probably because the rotors are slotted and cross drilled instead of just slotted. But it's also depending of the temparature, humidity,etc.
    But I have to say that was the first time I did brake mod, I haven't change any parts yet. I can say that I'm fully satisfied with this set up exept for the noise. This mod really worth it for the price.
    Hope this will help
    Veteran Member Four Rings Crazy Quattro's Avatar
    Mar 05 2004
    2004 A4 1.8t
    chicago
    just to make sure, but i need 11.3 sized rotors for the s4 calipers, rite?
    Veteran Member Three Rings kill4surf's Avatar
    Apr 28 2004
    2021 Premium Plus e-Tron
    no, 12.6 or 321mm x 30mm
    21 Audi e-Tron
    23 Audi A4 S-Line Black Optic
    19 A5 S-Line Sportback GONE
    18 Q5 GONE
    15 A4 S-Line GONE
    09 A3 GONE
    07 A4 S-Line GONE
    03 A4 1.8t Revo Stage 2 GONE
    Veteran Member Three Rings 1/4 scale's Avatar
    Mar 03 2004
    North Carolina
    I'm running Hawk HPS, Stoptech SS lines and Zimmerman slotted by ECS. Terrific initial bite without any noise. I didn't touch the rears (except for a previous pad change to EBC greens). Fluid is ATE Typ200. This is a great set up for my application. The car is so much more predictable during hard braking.
    2002 A4 Avant 1.8T • APR +1 • DSMIC • JJ tip • RS4 mounts • SB OFE HD • Apikol snub • B5 S4 binders • 18" Ultraleggeras w/ Conti D/Ws • APR exhaust • APR TBHose • Stasis SS • S4 rear sway • AMS ss • e-codes • Pzwo lip • S4 blades • USP roof spoiler • Apex track studs
