Results 1 to 13 of 13
    Veteran Member Four Rings Chard's Avatar
    Question anyone have the tool to change brake pads?
    I have to change my brake pads and just found out that I have to have some tool to change the rear pads. Does anyone in the Bay Area have the tool and want to help a fellow bruddah out?
    Veteran Member Four Rings quattro30v's Avatar
    01' S2K | '98 A42.8Q | '04 C32
    Re: anyone have the tool to change brake pads?
    i think Neo has one...
    01 S2000 - Some Torque (IRTB, AEM EMS)
    98 Audi A4 - LOTSA Torque (GIAC)
    04 C32 AMG - HOLY SH!T
    04 Mini Cooper S - DINAN-S2 (daily driver)
    09 Ducati HyperMotard 1100 - crotch rocket
    I'm gonna go ahead and change my front pads since you don't need the tool for the fronts. Maybe I'll catch him online later on tonight.
    you can try it without the tool, use a big needle nose pliers to rotate the pot, make sure you open the bleeder valve first, it should be easy to rotate once the bleeder is open.
    i'm having problems getting the front caliper to slide off. got 2 bolts and C clip off. anything else?
    Senior Member Two Rings Arnold D's Avatar
    Fremont, CA
    I've got the rear brake tool you can borrow. PM me later if you want it.
    It looks like you got the right parts off according to these instructions
    K, where in the heck do you get a 7 mm hex key? All my sets have everything BUT 7. They all go from 6 to 8. I'm going nuts over this install!!!
    Veteran Member Four Rings neoprufrok's Avatar
    NOR CAL
    Chard.. let me know if you still need it. I have it. Its really nice and works well.
    Currently:
    2018 GT3 Touring - Graphite Blue Metallic
    2016 McLaren 675LT - Mexico Blue with Roof Scoop
    2019 BMW M4 Convertible - Yas Marina Blue Competition Package
    Will be missed: 2001.5 Audi S4, 2004 Audi A4, 2004 Audi A8, 2008 Audi RS4, 2016 Porsche Cayman GT4, 2018 Porsche GT3.2, Mercedes C63 Black Series, McLaren 12C Spyder
    Podcast and Instagram: The Throttle Dogs
    I'm going to try and borrow one from Arnold. Thanks anyway, I appreciate it. This project has turned into a nightmare. I've left the car on a stand so I can continue the work tomorrow. I hope it's smooth sailing tomorrow.
    NOR CAL
    Yeah, sometimes it can get challenging. You just gotta let it be for awhile sometimes. When I start saying f*ck after every word and its past 2am... I know its time to throw in the towel.
    Currently:
    Ok, I'm back at it again. The pass side was much easier than the driver's side (mainly because I have the right tools...THANKS ARNOLD!). I think I'm going to check the driver's side again before doing the rears. Man, this is killer on the lower back!
    changing 4 brake pads should take 1 hour max! ok maybe 1 and 15min.
    NOR CAL
    30 minutes
    J/K Rich.. i think its awesome that you're doing your own work! More car enthusiasts should.
    Currently:
