Results 1 to 7 of 7
    Active Member Two Rings EricLt1's Avatar
    May 21 2007
    2006 A4 2.0T Quattro
    Westlake Village, CA
    Eurocode DV Replacement
    So after getting the Neuspeed ECU flash I got to know what my CEL looked like. I ended up breaking 3 stock DVs. So last week I installed the Eurocode 2.0FSI DV Replacement Kit. They claim it will not throw codes. Within 2 days mine did. The whistling sound it makes is great, but I am concerned with its performance. Anybody else use this thing?
    May 21 2007
    Re: Eurocode DV Replacement
    Thanks for the links. But there was not anything in there about long term satisfaction with the product. Mostly about how old one of the posters is and more about how long ecode takes . I'm looking for specific feedback about people getting DV codes and CEL. Also, re: the install, the instructions call to tie into the brake boost line for vacuum. The audi tech who installed mine used a jack going directly into the intake manifold. Any thoughts on that?
    Thanks
    Registered Member Two Rings sean8989's Avatar
    Jan 05 2007
    2005.5 a4 2.0t fwd
    los angeles
    mine didnt throw any codes... audi dealership doesnt even care i have it.
    diverters are all same. the dv replacement is just a silenced blow off valve. I have no trouble so far, and also i dont hear any difference in the two valves... I had it installed along with the ecode tp, i thought it was the dv replacement that was making the farting sound but when i took off tp, i realized it was the tp that made the sound.
    91 APR // ECODE TESTPIPE // ECODE DV REPLACEMENT
    May 21 2007
    So your DV didnt make any extra noise? Mine does. Maybe its installed wrong but it sounds pretty sick. Not sure how the guy installed it wrong...he is a master tech at the audi dealership.
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Do not go ditectly to the manifold as it sees both boost and vacuum, the brake booster sees vacuum only because of the one way valve.
    Registered Member Four Rings
    Apr 24 2007
    Great Lakes of SoCal
    read up on it on VwVortex...causes surging issues which can damage your turbines
