Results 1 to 21 of 21
    GIAC-X max boost?
    I just got my vent boost gauge installed and I noticed that it peaks at 15-16lbs. Usually the boost holds at around 15lbs and rarely goes any higher than that. I've got the Forge 007 valves w/ the yellow springs. Any advice? Are these correct readings?
    Feb 24 2004
    02 S4 & 67 Goat
    So Cal
    Well in bars....I hold at 1.1(15/16psi)/1.2(17psi) bar and I've spiked at 1.46(21psi) bar.
    Wow, the highest it's ever spiked was at 18lbs, but I rarely see over 15lbs.
    Feb 24 2004
    02 S4 & 67 Goat
    So Cal
    Have you checked for leaks?
    Apr 12 2004
    2000 stgIII s4, 1997 jeep
    denver
    yo.
    i have the same chip on a 2000 with an AWE center vent boost gauge, and i will see 20-21 psi, but usually tapers off to 17-18psi.
    r u kidding me? are you sure you're not running the xr chip?
    Apr 12 2004
    denver
    i thought it was the x chip, but it could be xr. i should probably know these things. i had it installed this spring.
    no kidding, all boost.
    wow that seems really high boost levels for the X chip. Careful you don't toast your turbos with that chip. :P
    Feb 18 2004
    Brooklyn
    the x chip should hold at around 18psi and spike at about 21 at least that is how mine is
    definitely check if u have a boost leak
    did u get ur chip new or used cause if it is used make sure u have the most up to date software on it
    aka NYC_SpeedRacer
    Feb 24 2004
    02 S4 & 67 Goat
    So Cal
    Yes these numbers are correct for X chip. Like I said before check for boost leaks and like Doo said update the software. But I think your leaking somewhere.
    Another thing is, that while driving people seem to miss what the gauge spikes at b/c it is so quick. Have someone else watch the gauge while you are driving it to make sure your not missing it since you dont have the max/peak hold option on your gauge.
    Orange County, CA
    the XR chip is a race gas program... if you didnt know you had it, and youve been running 91/93 then youd know it cause your car would ping like mad.
    B5 Parts For Sale
    Veteran Member Four Rings twinsnailsS4's Avatar
    Richard Henry Dana Jr.
    FYI, the last version of the x-chip was supposedly producing an average of 1.2 to 1.3 bar according to GIAC's old website. I believe V.7 was 1.1 to 1.2.
    BTW, there is also an XRR chip which is geared towards road racing (better timing) rather than flat out drag racing like the XR.
    Current: B5 S4 Avant, F10 M5 (comp pkg), 14' Tundra (4x4), Lexus CT200h, BMW S1KRR
    Past: W212 E63, C6 A6 Avant, B5 and B7 S4 Sedans, FD RX7, a Civic Hybrid and 2 Beaters
    Feb 24 2004
    02 S4 & 67 Goat
    So Cal
    "supposedly producing an average of 1.2 to 1.3 bar according to GIAC's old website"
    That is v.5 some people still run it.
    I know, the language you quoted sounds shaky, but their older website did state those numbers; I should have just put "IIRC." I know they all spike, but i thought v.5 (not "v.7" like I wrote, that's APR sorry ) could not average 1.3 like the current version since the smoothness of the chip was improved so much (the smoothness is the biggest difference anyway).
    At any rate, I have also spiked at around 1.43, but stay pretty much at 1.2 with taper down to about 1.0.
    Mar 16 2004
    B5 S4
    jersey
    My dads S4 is running Giac x-chip and people say its not that smooth, but once we put the awe-twin-2 then a k valve in it it runs a lot smoother then when it only has chip intake and dv's.
    2000 Silver Audi S4
    GIAC X-Chip
    ITG S-Flo
    Forge Diverter valves
    Awe Twin 2
    N75K Valve
    Stoptech Slotted rotors
    Axxis brake pads
    RS4 grille
    Feb 24 2004
    02 S4 & 67 Goat
    So Cal
    You sure its an updated version? the awe twin 2 cat back helps though.
    Apr 12 2004
    denver
    whats the N75K Valve ????
    does anyone with giac have the chipswitch???
    Feb 24 2004
    02 S4 & 67 Goat
    So Cal
    hero, the n75 is the wastegate bypass regulator valve located in the rear of the motor(its stock). If you have the correct software, the ECU will open the wastegates at the right rpm and dump valves via the N75 valve to limit the boost. Some people also use the MBC in parallel to make sure you limit the boost so it doesn't spike at +19 psi. However I will put money on the fact that you have a boost leak, pressure test the system and go from there before you start adjusting or replacing(n75) or adding(mbc) parts. BTW for questions such as these you are better off searching the Audiworld forum or asking the members. As for the chipswitch if you are talking about the IBE 2, I heard that they are having problems with this version 2 and that they are going to be releasing the IBE3 soon to take its place, I havnt heard anyone that I know personally that is using it.
    Is there any way to tell which version of the GIAC software I have? I believe its v8 but for all I know they could've lied to me about which version it was.
    Are you guys seeing ~17-18lbs in 6th gear or others as well?
    Feb 24 2004
    02 S4 & 67 Goat
    So Cal
    "Is there any way to tell which version of the GIAC software I have? I believe its v8 but for all I know they could've lied to me about which version it was."
    I could have sworn I replied to this yesterday, guess it didn't post. Anyway if you open up your ECU box and look at the chip. You will see the GIAC chip soddered on and it usually has a GIAC sticker with a blank spot to write the Version # and prob the date updated. So just open up your ecu box and you should know. Be very careful not to f-up the chip.
