Results 1 to 9 of 9
    Veteran Member Four Rings audibmi's Avatar
    Apr 05 2004
    8S TTRS C8 RS6
    pnw
    Modifying the switchblade key
    Anyone taken apart the switchblade key before? Is there anyway to modify the key so one does not have to depress the button in order to close the key? The Mercedes ML series and the current SLK has a similar switchblade key, but its much simpler to close because there is no button to depress and unlock...it's essentially spring loaded in both the open and close position. Just a thought for those extremely lazy
    Veteran Member Four Rings fongaroos's Avatar
    Feb 12 2004
    cali
    id like a way to modify it so that there is more "reception"
    i feel like i have to be RIGHT NEXT TO THE CAR before it receives the signal from the key fob. maybe my batteries are low... but my car is only a few months old... so i dont think it should be that...
    hmmmm...
    Veteran Member Three Rings dicksongo's Avatar
    Mar 29 2004
    i remember i saw it somewhere that said the low reception is because where the reciever is being placed...
    it is located like under the rear seat or something, i forgot
    Dickson the photoholic
    http://www.dicksonsimages.com
    Veteran Member Four Rings zemun2's Avatar
    Feb 20 2004
    '04 A4 1.8t FWD APR Tuned
    Zemun, Serbia.
    Mine works fine even from 150 feet away.
    APR Tuned Serbia
    Authorized APR Distributor
    Veteran Member Four Rings HyperM3's Avatar
    Mar 20 2004
    Lawrenceville, NJ
    Yeah, mine works fine too. Like always, put it up to the base of your chin to get the best reception.
    21 S5 Coupe - RacingLine strut brace/034RearSwayBar/CTSTransMount/034 tune/VPS Res Delete/CTSIntake
    10 S4 (gone),13 S6 (gone),14 S6 (gone),14 S6 (gone),16 S6 (gone),17 A4 (gone),19 S4 (gone)
    20 BMW R1250RS
    ACNA Lifetime Member - 26690
    Respond to a post with an answer, they will keep asking questions. Teach them how to RTFM, they will learn to help others.
    Feb 20 2004
    Zemun, Serbia.
    Exactly like that
    APR Tuned Serbia
    GTA, Canada
    I've opened mine up, but don't see why its worth hacking in order to get it to stay open or closed without the button.
    Check your batteries if you reception is that crap, but the chin comment will work.
    RippleChip (Ryan) - Moderator
    Audizine
    01.5 eh4 1.8T || 12 eh5 2.0T
    Established Member Two Rings teknik's Avatar
    Mar 20 2004
    FL
    I think you can move the antenna for better reception, check AW tech articles.
    ///MONEY PIT MOTORSPORTS
    95 318ti S52 Turbo aka The Money Pit
    95 M3 - DD - Green Machine
    Veteran Member Four Rings hyperspeed's Avatar
    Feb 13 2004
    Chino Hills, CA
    wrap it in foil lol
