Results 1 to 12 of 12
    Veteran Member Four Rings needforspd's Avatar
    Mar 05 2004
    Deceased 01.5 A4 1.8tm
    Sylmar Hills
    Unhappy So car had CEL on all week, finally had time to take it in ..
    Had my CEL on all week, took it into Jose to fond out the codes this morning.
    Looks like I need a new throttle body (something on it isnt working right and its probably what's causing my stalling) and air/fuel meter or controller (forgot which he said, but its not reading right on the VAG). Though he said it might be under "emissions warranty" to get both fixed?
    Also need a new DV which I knew about a couple weeks ago.
    Car has 686XX on the clock. Why is this normal for an Audi to fail on? Pissing me off, just got the car early April and I have to drop more $ into it. I guess thats what I get for buying a German car huh?
    So my question is if this stuff isnt under warranty what am I looking at $$ wise for replacing?
    Bleh
    Do you have a need for speed? Then drive it like you stole it!
    Feb 12 2004
    2018 M3 CS, i3 REx
    Orange County CA
    throttle body was close to $300 plus labor iirc. I was under warranty, so it was covered. I could be wrong, since this is all from an invoice I didn't get a copy of (my invoice says (N/C). Mine gave out at 59k miles, so it's not out of the ordinary.
    Di he say it was also the MAF?
    Good luck man!
    Former:
    BMW F80 M3 CS
    BMW F80 M3
    BMW I01 i3 REx
    BMW F30 340i M Sport ZTR
    Audi B7 S4 25Quattro
    Audi B5 A4
    Mar 05 2004
    Sylmar Hills
    Nah didnt mention anything about the MAF.
    Did you have an extended warranty on your car? or was it covered under whatever the normal warranty is?
    Cuz I couldnt find anything on AoA's web site about an emission warranty.
    This blows.
    Good luck man!
    Feb 12 2004
    2018 M3 CS, i3 REx
    Orange County CA
    I bought the car used certified from the dealership, so it is extended to 100k.
    Former:
    BMW F80 M3 CS
    BMW F80 M3
    BMW I01 i3 REx
    Audi B5 A4
    May 02 2004
    99.5 1.8tqm
    Flemington, NJ
    do the dv yourself. really easy. not sure about the throttle body. it ran me 400 parts/labor. the dv should run you about 30 bucks. do it yourself so no labor
    4 wheels
    2 headlights
    1 glovebox
    1 ac unit
    1 radio
    1 engine
    Mar 05 2004
    Sylmar Hills
    Yeah the DV I figured Id do it myself. 710N is like $40 I beleive. Have a Turbo XS right now and dont know how or if it can be fixed.
    Active Member Four Rings
    Feb 18 2004
    Audi A4
    East Aurora NY USA
    DV takes like 30 mins the first time, taking it super slow, including jacking the car up and shit.
    After that you'll be like wow, 10 mins to do that. :)
    Throttle body; is there anything aftermarket for that? Always try to go aftermarket when you break something. :)
    i like my black girls clean and my white girls dirty.
    doesn't matter either way they're all out to hurt me.
    Veteran Member Four Rings 1.8Titorey's Avatar
    Mar 04 2004
    97 A4
    Fremont ca
    you can get a used throttle body for 175 at rpi equipped. not sure how much they run brand new.
    http://www.rpiequipped.com/store/c192470.2.html
    Registered Member Four Rings Zodiak's Avatar
    Washington DC
    yeah go with used throttle body, any good independant mech should be able to source one for you.
    Veteran Member Four Rings 4ingDrive's Avatar
    Feb 25 2004
    Chi town burbs
    I've got a used tb. Pm me if interested.
    99.5 A4 Avant
    always some shit broken
    Jun 09 2004
    93 Mustang, 97 A4
    Harrisburg Pa
    I dont understand how a TB can go bad. My girlfriend's 97 had a stalling problem and the idle would dip/fluxuate at idle. I took of the TBcleaned out the carbon residue with WD and a brillo pad. I also pulled out the sensor behind it and wiped all residue off of it. Problem solved and it only cost me 1/2 hour of my time, not 300 that the dealership wanted.
    Rick
    93 Mustang
    97 A4 1.8TQA
    Mar 05 2004
    Sylmar Hills
    Thanks for the input guys. Yeah I dont plan on getting a brand new TB if thats what it comes down to. Jose can get me a used one Im sure w/ no problems. I will probably try a cleaning of it first thought before replacing it and see if that helps.
    Though its the actuators (sp) in the TB thats causing the problems and Jose said thats not something that can be cleaned.
    And it is my MAF thats seems to be going also. He said Air/Flow meter and it didnt register with me right away that it was the MAF. So now to call AoA to see if Im covered.
