Results 1 to 3 of 3
    Registered Member Three Rings
    May 28 2004
    00' VW MKIV GTI GLX
    PNW - 509 reppin' hard
    Gauge Cluster Lights are going out...
    The lights that light up my gas and temp gauge went out the other night, and just last night one of the lights that lights up the 0-20mph section went out as well.
    How hard is it to pull the cluster out to replace the lights?
    Also, what type of bulb do I need for it? Anyone have a part #??
    Thanks guys, in advance.
    MKIV GTI GLX
    Feb 17 2004
    Sterling, VA
    ECS sells them, they're cheap.
    You have to pull out the cluster. You should be able t oswap the bulb without opening the cluster. IIRC, they use a twist-lock type base on the backside of the cluster in various places.
    Brett - Moderator
    Issue?: email me.
    _____________________
    Stage 3 2004 A6 2.7T 6M
    May 28 2004
    00' VW MKIV GTI GLX
    Ohhhhhh man! Thats awesome news, thanks Turbo! I'm horrible at fixing things, I always end up breaking stuff, so if theres less to do, than the better! :) Thanks again Turbo, I appreciate it. :)
    MKIV GTI GLX
