So, I decide after reading the AW tech article to do this.
I go out, pull the bulb cluster, Dremmel out the hole, buy the new bulbs and then I notice that there's no metal connector for the contact on the bulb.
So I pull the opposite, working side, and it's got one in there. *Tech article didn't cover this... So, in my brilliance I rig something so ridiculous...well, it's the clip off of a pen if you must know. It's metal, the same size and with a little adjusting it fit's and makes contact perfectly...
Then I switch it on and pop, fuse goes...
No biggie replace fuse, pull out the sweet rewire I did and all is back to normal...
But i would like to put in the 2nd side bulb. What do I need to do to get this to work? Is it not possible or should a proper connection, saudered in do the trick?
Sorry for the long explanation....
Thanks...
