Results 1 to 9 of 9
    Senior Member Two Rings BuffysRS4's Avatar
    Jun 12 2004
    Audi A4 1.8T, Audi Q7 3.6 Prem
    Markham, ON - Eastvale, CA
    Angry Keyless remote antenna
    does anyone know which wire under the rear seat is the antenna for the keyless remote? I read somewhere that I can increase the range of the remote by running the wire/antenna up around the parcel shelf.
    "Speed kils, drive better"
    2007 Audi Q7 3.6 Premium
    2004 Volvo XC90 T6 AWD (TRADED POS)
    1999.5 Audi A4 1.8TQM
    1996 Mitsubishi Montero LS
    1993 Geo Storm SiR (RIP)
    1992 Mazda 323 (RIP)
    Registered Member Four Rings Zodiak's Avatar
    Washington DC
    for 99.5 the antenna unit is in the trunk IIRC. That tech article you're refering to was MY specific
    Feb 13 2004
    <> Posts: 9913
    It's a myth, only applies to '96 models from what I've been told. Just hold it up a little higher in the air (head high) and it will work from further away.
    (I'll never understand why people want to unlock their car from hundreds of yards away.)
    For what it's worth, I live on the 2nd floor and I can easily roll up and down my windows with the remote from there. It's all about getting above the antenna.
    -Theodore Roosevelt, 1907
    Established Member Two Rings silveravnt's Avatar
    Feb 21 2004
    B6 Avant + AR 6MT + T100
    The Sticks
    I would settle for anything more than 5 feet. Yes I have replaceed my batteries and it helped for about a day.
    There is a TSB regarding a improved antenna
    Veteran Member Four Rings Burntaudi's Avatar
    Sold:1997 Audi A4
    Maplewood, Minnesota
    here you go http://www.20vturbo.com/tsb/mirror/audipdf/57-98-02.pdf
    Alex
    Sold 97 Audi A4 Turbo Quattro Manual
    KO4/GIAC PC-16/GHL Exhaust/EVO FMIC/ Southbend Clutch/JHM Short Shifter & Linkage/Shifter Bushing/Koni Coilovers/Neuspeed Sways/17" OZ Superellegras/Ecode Headlights/VVME Hids
    Current ride 03 Tahoe Z71
    Veteran Member Four Rings nizmosx's Avatar
    Feb 13 2004
    2007 b7 a4 6MT Ti avant / 1990 300zx TT / 2014 Honda Grom / 2012 Tiguan SE
    Lakewood, CA
    honestly IT DOESNT WORK, my brother done this mod and changed his on his 97 to the newer one and its worse. his remote range is horrible. once it gets older its something you have to deal with. he replaced wire and batteries in remote in hope for more range now whenever i drive his car i use the key because even when your standing by the door its debatable if it will work.
    you can try it but it didnt work for my brother. g luck post results
    Veteran Member Four Rings AudiSnawb's Avatar
    99.5 Audi A4 2.8 Quattro & 2001.5 VW Passat Sedan
    Derry, New Hampshire
    I dont care about UNLOCKING my car more than 5 feet away.... just disarming the alarm, when it ALWAYS goes off when my window is cracked....
    There's No "I" In "Team America"
    Veteran Member Three Rings Brrman's Avatar
    Indianapolis
    Didn't work for me either - the range is the same. I extended the range of the antenna wire and I got no difference whatsoever.
    2019 S4 Prestige
    RIP... 2013 A4 Allroad
    SOLD 2007 A4 2.0T S-Line Ti (APR stg1, Koni Coilovers, LED Tails)
    SOLD. 2000 A4 avant 1.8T (GIAC stg1, Bilstein/H&R)
    RIP... 1998 A4 1.8T (GIAC stg1, Bilstein/Neuspeed)
    Washington DC
    press the button on the b-pillar. before you lock it with the windows down
