Results 1 to 11 of 11
    Registered Member Three Rings BrokenXenon's Avatar
    Apr 28 2004
    exhaust leak [neuspeed]
    couple of days ago... i noticed that when i start the car in the morning... i hear some kinda whistling sound coming from the back. and it gets louder when i hit the throttle. so it's throttle dependent sound.
    so i looked under the car this morning... i hear pssssshhhhh sound from the rear of my car. i guess it's an exhaust leak.
    how bad is exhaust leak? and how much would it cost me to fix this?
    03 A4 Avant, 85 ABA Golf
    Palo Alto, Ca
    Well, is there a hole or is it just one of the clamps is loose?
    Feb 10 2004
    2019 Mk7.5 Golf R His/Her
    Eastvale
    check this out...check the cross member arm that holds the rear portion of the exhaust. it's the part that is bolted in the middle w/ an adjustment slider...the tubing that's used is somewhat thin especially in the bend area and where it's welded cause the leak...have a look
    Instagram: @daohaus_garage
    Veteran Member Four Rings giago's Avatar
    Feb 12 2004
    audi a4 1.8t 2002
    Mexico
    It could be the same i have, well from what you tell i have the same noises.
    I wil take some pics and post them later.
    so you can take a look and see if it is the same part.
    Apr 28 2004
    wow thx for the infos guys
    Feb 10 2004
    Eastvale
    you can barely see that horizontal bar...check the weld area around the horizontal bar(s)
    Apr 28 2004
    Hey foo thx for the infos.
    i wanted to tell you that the "sound" stops after driving for awhile. do you know what could it be?
    the sound is not that serious but it's very annyoing.
    like a metal grinding noise... 'wheeeeeeee"
    Feb 10 2004
    Eastvale
    well it could be that the metal heats up and seals it? but check that and the joints to ensure that they're all properly sealed.
    Feb 12 2004
    audi a4 1.8t 2002
    Mexico
    if it is a metal noise is not my case.
    in my car sound is of a gas whistling.
    Apr 28 2004
    ok i am not so sure what it is..
    it sounds like a whistle but somehow it sounds like metal as well.
    i am so lost. i need to bring my car in
    Feb 10 2004
    Eastvale
    trust me...when my friend's weld joint broke...it sounded like metal as well as hear the gas coming out...
