Originally posted by UltraAvant
I just went with the REVO tuning for my Avant but have not yet purchased an SP unit yet. My question is how much of a difference in power will the SP3 be running High Boost + 2 over the standard SP1? I don't want to play with the timing and cause any extra problems for myself. I already have the Thermal Exhaust and DV with no plans on a turbo upgrade in the future. Is it worth the extra $$$?
Please help!!!
The "standard" Revo code is designed to work with a typical, or most likely, set of conditions found out there such as temperature, octane, etc. SPS3 allows you to change the code to adapt it to environments that differ from the typical.
For example, if you fill up with 100 octane, you can change the timing and boost to take advantage of the higher octane. But if there is no marked difference from Revo's expected environment, there is not much that SPS3 can do.
Maybe sps3 will allow you to find 10 additional horses here and there after careful tweaking but I dont think 10 horses are worth $350.
But that's only my opinion -- I could be wrong.
btw I did get the sps1. If my car dies in the middle of nowhere and it has to be towed directly to the dealer I want to be able to switch to stock mode before the dealer gets it.
