Originally posted by giago
I was thinking of getting the STaSIS Street Sport suspension.
Would it be Better that a sping shock combo??
My other option was eibach, h&r or neuspeed springs whith bilstein shocks.
But i want to know whith which one of all those springs i will have the stiffer ride.
What is the spring Rate??
Any opinions??
STaSIS "Street Sport" / Koni CO = Same Thing.
IMO, CO's are always the better choice to an "off the shelf" spring/shock combo. With height adjustibility, you get exactly the look you want (plus some damper adjustment with some; Koni, KW V2/V3,..). Spring/shock combos are also not R&D as a pair, so there's no telling how they will interact in terms of ride quality and height; that's why you see/feel the differences between them on the same app. There are only a couple set ups I know of that are; H&R's Cup Kit and Sportec's Lowering Suspension Kit.
I have H&R CO's and I'm quite happy with them. There a bit firmer riding then ABT or Oettinger CO's, but they give me the handling, control I want. Not sure how they compare to the STaSIS/Koni CO's though. Regardless, the CO set up will be noticeably firmer then OEM, and for the most part, firmer then a spring/shock combo (depending on damper and spring type/rate).
At $995 for the STaSIS/Koni CO's, that's hard to pass up for a spring/shock combo priced not much lower. Just buy them direct.
