Results 1 to 7 of 7
    Registered Member Three Rings
    Feb 12 2004
    2000 Audi S4
    NoVA
    Thumbs up On my way to the timing belt!
    I'm almost there. I just need to drain, disconnect, and remove the radiator and then everything will lift away!
    2000 Nogaro Blue S4 stg2+
    Apr 12 2004
    2000 stgIII s4, 1997 jeep
    denver
    ATTA BOY!
    Veteran Member Four Rings twinsnailsS4's Avatar
    Richard Henry Dana Jr.
    I will buy you lunch if you change mine Good luck to you and your knuckles.
    Current: B5 S4 Avant, F10 M5 (comp pkg), 14' Tundra (4x4), Lexus CT200h, BMW S1KRR
    Past: W212 E63, C6 A6 Avant, B5 and B7 S4 Sedans, FD RX7, a Civic Hybrid and 2 Beaters
    Veteran Member Four Rings DRA4's Avatar
    Feb 12 2004
    B5 S4
    Good job.
    Giac stage 1 279whp-327wtq
    TEAM A.C.E. NY
    Me: Siri where do lesbians hang out?
    Siri : I found 2 Subaru dealers fairly close to you
    Feb 12 2004
    2000 Audi S4
    NoVA
    Thanks guys! So far no busted knuckles, but I did cut my elbow on the part of the hood that is normally covered with the weather stripping.
    Feb 12 2004
    2000 Audi S4
    NoVA
    I got a lot done today.
    Now I can see the belts
    My radiator was filled with OJ...wtf?
    Me and my kitty looking tired
    The glam shot
    Active Member Four Rings Ben@SpeedBarn's Avatar
    03 A6 2.7t, 00 GTI, 76 GMC
    Pittsburgh, PA
    Sweet. I did my a4 last spring and it was crazy. Not super hard but time consuming. It took me and my dad between 8 and 10 hrs probably. I am getting my s4 saturday so i probably will have to do it in a few years. Good luck on finishing.
