Results 1 to 9 of 9
Thread: Octane?
    Veteran Member Four Rings initiala4's Avatar
    Feb 24 2004
    Land of the smiles
    Octane?
    Just curious are there any advantages in putting 100octane into our cars?
    2019 B9 RS4 - O.CT Tuning Stage 1 | Wagner Intercooler / Radiator | JBOM 100 Cell downpipe | Ohlins R&T DFV | 034 Motorsports Dynamic + Sway bars | 034 Motorsports Transmission mount | Ignition Projects Coilpacks | HHC Rear rotor upgrade 370mm + Endless MX72 brake pads
    Formerly - 2003 Audi B6 A4 1.8T QM, 2013 VW Passat Variant 2.0 TSI
    03 A4 Avant, 85 ABA Golf
    Palo Alto, Ca
    Of course!!
    Feb 24 2004
    Land of the smiles
    Mmm most powa?
    Registered Member Four Rings
    Mar 05 2004
    2003 Audi A4 1.8TQM
    Calgary
    just make sure you have the right programming !!! Otherwise, you are running rich and could damage catalytic converter as I was told.
    Palo Alto, Ca
    Naw.. running higher octane gas wont make your car run richer.. The programming is need to take full advantage of the higher octane, but its not needed..
    I could feel a difference between 91 vs. 100oct on my old car.. I didnt swap chips or anything..
    Veteran Member Four Rings Mark's Avatar
    1959 MGA 1600
    Chocolate Land, USA
    I just run 93 octane all the time. Sometimes, when I feel like it, I'll go 94 octane . . . and perhaps a gallon of toluene to raise it to 95 . . .
    go East Coast!!!
    -Mark
    1987 5000 CS TQ 2.2T I5 - No more . . .
    2002 Denim Blue A4 1.8TQMS - RIP
    2005 Ebony Black Pearl allroad 2.7TQMT6
    Kinda stock . . . Tinted, H-Sport Sways, HP-2 Calipers, RNS-E, Bluetooth, and iPod/Sirius combined
    Got Vag-Com?
    Veteran Member Four Rings zemun2's Avatar
    Feb 20 2004
    '04 A4 1.8t FWD APR Tuned
    Zemun, Serbia.
    Running rich is not big deat, but running lean is major problem.
    I get 20WHP more on 100 octane.
    APR Tuned Serbia
    Authorized APR Distributor
    Registered Member Four Rings A4NCAR's Avatar
    Feb 12 2004
    Re: Octane?
    Mostly the "profit" advantage to the station But seriously, there is definitely more power when using 100 octane. But w/o a chip specifically programmed to take advantage of it, it's not worth it (unless you're doing a track day). Plus, it's expensive. Just run 91 octane for stock and with some chips. But use a higher octane with chip if possible; like 92/93 octane.
    Veteran Member Four Rings cj-S4's Avatar
    Not enough space here
    Somewheretown, PA
    IMO, its not worth it unless you are running 100 octane specific programing for it. At $5.00 a gallon last I checked, and that was before gas started to go up,, it just does not yeild signifigant enough gains to throw out the cash.
