Results 1 to 7 of 7
    Sep 17 2006
    Audi A4 1.8T B6
    New York
    Check Engine Light - Thermostat problem
    My check engine light was on and I got it vagged. The shop told me that the problem is with the thermostat. The engine temprature has been showing fine on the dial. I got it reset and it came back on again after a few days.
    1) Any thoughts?
    2) Cost to get it replaced.
    Thanks a lot for your help.
    Oct 16 2006
    Naperville
    Re: Check Engine Light - Thermostat problem
    with the thermostat, you fan should come on when you first start the car... it loud as hell too. This was how my car acted with a thermostat problem.
    Veteran Member Four Rings Elberoth's Avatar
    Feb 18 2004
    1990 Ferrari Testarossa
    Warsaw, Poland
    Just replace it. It is dirt cheap. I replaced mine (I have 80k miles on my car) 2 months ago for the piece of mind.
    2021 Audi R8
    2012 Porsche Cayenne
    2010 Audi S5 - facelifted F & R (sold)
    2010 Audi Q5 2.0TDI facelifted F & R (sold)
    2002 Audi A4 1.8T Sportec K04 Stage II (sold | will be missed)
    Oct 16 2006
    Naperville
    wait? how is our thermostat dirt cheap? i paid about $100 bucks for it. most car thermostats are like 10-15 bucks
    Aug 26 2005
    Quote Originally Posted by kapil403 View Post
    1) Any thoughts?
    What was the exact DTC number the scan revealed stored in the Fault memory?
    If your A4 is a 1.8T, the TStat, has a heater element inside, controlled by the ECU, and varies the engine temperature depending on engine load/speed maps programmed in the ECU. A replacement TStat, costs about $100+
    The only DTCs referring directly to the TStat, involves a failed heater element inside the assembly, or an electrical fault with the circuit connected to the heater.
    Established Member Four Rings A4TL's Avatar
    Nov 06 2006
    335is
    atlanta
    bet its the coolant flange and green cts!
    Feb 18 2004
    Warsaw, Poland
    Quote Originally Posted by manguyen View Post
    Sorry, you are right. That was a coolant temp sensor that was dirt cheap (15$ or so). I replaced several sensors all at once, chence the mistake.
    2021 Audi R8
