Results 1 to 9 of 9
    Feb 24 2004
    SD
    15.6 mpg on 99.5 A4 1.8T auto tip...Need help
    No CEL. Just poor mileage, according to the trip computer (Average MPG always around 15.6 mpg; Immediate MPG is good).
    I've noticed, however, that when shifting with tip I get a slightly better mileage, possibly due to me keeping the revs higher (more torque, less work on the gas pedal).
    Just recently installed NGK BKR6E spark plugs.
    Need help.
    Thanks.
    Veteran Member Four Rings cj-S4's Avatar
    Not enough space here
    Somewheretown, PA
    When the last time you checked your air filter? That can make a big difference if it is dirty.
    Forum Moderator Four Rings blacka4's Avatar
    Dodge RAM 1500
    Pittsburgh Area
    wow man I would check your filters and make sure you gaped those plugs right. I get about 25 arould town and roughly 33 on the highway...but I'm crusing at about 75 the entire time
    -Rob - Moderator - PM Me!
    RIP:1999.5 Audi A4 1.8TQ Tip Brillant Black
    2009 Dodge RAM 1500 Crew Cab Sport - AZ Plate Frame - Bone Stock otherwise
    2014 Jeep Grand Cherokee Summit
    Registered Member Four Rings joeya103's Avatar
    Apr 04 2004
    98.5 A4 1.8T Tip FWD
    Northern VA
    also try some fuel injector cleaner, it supposedly helps out noticeably with gas mileage
    Feb 24 2004
    SD
    Forgot to mention that it has a new air filter as well.
    And, when I had a problem with TBA a couple of months ago I did run a can of SeaFoam through the fuel system.
    Established Member Two Rings wakko's Avatar
    Apr 08 2004
    Temple City, CA
    actually I also have had bad millege with my car, and its been like this since day 1. I am thinking those numbers posted by AUDI really does vary among each car.
    personally I get 22-23 mpg with mix highway / local.....27 on all highway with steady 65-75mph.
    cheking the plugs should help you a bit, but not significantly
    2000 A4 1.8T FWD TIP / 20%F 15%R tints/GIAC 1.0/ GIAC TIP / Full 2.5" DP back custom exhaust / Flik WASP-A 18" / RS4 grill / Ecodes / OEM RS6 4300k HID / Reiger V1 sides / Painted Front lower / Molded SGI rear / Apex Cupkit Suspension / Greddy TT / AutoMeter Boost Gauge / Audi all-weather mats / Forge 007 DV
    Registered Member Two Rings
    Mar 28 2004
    ATL
    I've always gotten around 320-330 on a tank of gas in the city and over 400 on the highway.
    Patrick
    2001 1.8t Quattro
    Jun 18 2004
    Audi A4 1.8T Quattro
    nj
    i get 280 to a tank
    which means like 17 a gallon
    gay..
    help us!
    Veteran Member Four Rings bitterchild's Avatar
    Feb 16 2004
    audi is chit
    Did you gap the brk6e's? the 6e-11s come gapped correctly, the 6es do not.
